I was rereading the thread and was reminded you had asked for a report. I'm not the best person to get a review from as I have only had the Sharpmaker for a few weaks, and I have been sharpening exclusively with diamonds up until I got the sharpmaker. I ordered 80 grit triangle ruby, 220 square ruby, 400 square res cut, and 600 square y2k for polishing.
I was initially depressed that I had accidentally ordered square stones to use with my Sharpmaker, but as soon as I tried my triangle stone in the slots, I decided to tape it flat to the rods. My initial attempt was a crome vanadium straight edge knife. I attempted to lower the bevel to 25 using the corners of the 80 grit stone after I rounded the corners slightly against each other. This is where my inexperience with stones came in. I ground the edge into the stone thinking this is how the stone cut. With the edge cutting into the stone, I only succeeded in creating a convexed edge(a bad thing?). When I was done at 25 degrees raising burrs, I had to go as high as 40 degrees to actually get a honed edge. I didn't have this problem using my dmt hones against the rods. I was completely frustrated at my complete lack of success. The lesson learned here for me at least is don't use the corners of these stones, unless you have enough of a flat on the corners to keep you from digging into the stone.
I have since used the flats of all my Congress stones with much more satisfying results.
Taping the stone to the sharpmaker rods gives me precise angle control, and allows me to use the square stones which are much more stone than the triangle. My triangle stone looks pretty pathetic after I ground the edges down, and I now wish I had ordered all squares. The other day, I got frustrated taping and then removing stone after stone sharpening a few of my straight edge knives, and I had an apephany. I taped all three square stones to one rod. One stone per side using electrical tape around the three stones. The stones were secure during my whole process, and it provided a three grit combo stone for the sharpmaker. After I tried this, I was very pleased that I had accidentally ordered square stones. There is much more stone to deal with, and they work great taped in threes to a sharpmaker stone.
I'll give another report when I get a new low grit square ruby, and put a little abuse on it.
