- Jun 9, 2011
And cold steel move on and come up with something that much better than it use to.
Anybody still carry this
It was the best long time ago
Some guy in jersey was recently and got arrested.
And how do these two knives compare when used as knives for...you know...cutting things?
I'll wait for your answer, Cold Steel.
While I do like having a decent lock on my knives. the lock is not the reason I like that knife.
True that. I'm not a hard user of my folding knives, so I definitely fit into that group. As long as a lock is sufficiently strong to keep me from doing something stupid with my folder and hurting myself as a result, I'm satisfied. But getting all worked up over the lock in my folder makes about as much sense to me as getting all worked up over the seatbelts in my car. Call me silly, but I don't buy folders for their locks any more than I buy cars for their seatbelts. I buy folders to cut stuff and I buy cars to go places. Features like locks and seatbelts that allow me to do those things safely are important, of course. But they're not what I think about most when I make my purchase decisions. YMMV
Might be a bad contest if your goal is to show up Cold Steel on this one. Same stock thickness, same grind, but the Hold Out 2 has a broader blade which means a higher grind and a slightly better angle for slicing. Real world it would come down to which was thinner behind the edge and, realistically, that would probably go back and forth between the two based on the individual sample.
That's part of what cracks me up about Cold Steels marketing. Ignore that for a second and look at the knives they're actually making. They use thinner stock than many, many companies (Spyderco Military has 4mm blade stock, Recon 1? 3.5mm), the grinds and edges are generally much better suited to slicing than abuse and they've removed steel liners from almost every model they make.
Cold Steel licensed a tremendously strong locking mechanism so they market the hell out of it, but they clearly don't believe that strength is the most aspect of a folding knife or their designs would be very different. I like Cold Steel because they make a broad range of simple, working knives that cut well are lightweight and are very reliable.
That test was surprising. I figured the Triad Lock would be stronger, but what I did not expect is the compression lock to be one of the weakest locks tested. Go figure.
I appreciate these tests. My fingers are precious. No amount of rhetoric will change that.
Lock strength is somewhat important to me, but ease of opening/closing the knife is just as important and both fall significantly behind ergonomics and cutting ability in my selection preference.
Seems to me that's exactly what Cold Steel is doing here. And as you suggested, the aspect they're testing probably isn't the most important one to most knife buyers. But it sure seems as if Cold Steel would like you to believe it is.Or we can pick testing of one aspect.
Yep. Then again, grinds can be modified to suit your needs. And they're not nearly as sexy to talk about as lock strength . . .
Certainly none that I can discern. I'd say Cold Steel would gain about as much traction as they have here if they tested the lock strength of a Tri-Ad folder against a Buck 110. Cold Steel would win, of course. But who would care?No real world relevance.
Arguments aside I believe that what most are trying to say is that the Para2 lock is plenty strong.
It is probably the best selling knife at the $100-125 mark. How many people are getting hurt because of lock failure?
I have nothing against cold steel and I understand they want to settle the argument on who's lock is stronger.
It's just like watching a kid claim his dad can beat up your dad... No real world relevance
