Cliff Stamp said:
There was a passaround on the Pal, the performance is very low, no primary grind, edge way too thick for wood work.
-Cliff
Yes, it has a thick edge. A thin edge, like on the traditional machette, cuts into wood and sticks. Using alternating angled cuts removing "bites" from wood, the Pal cuts quite well without the edge breaking or sticking like a thinner machette might. The full blade thickness also gives it the heft for momentum to cut without the "spring" effect that sends a shockwave back up your arm. It can be used as a drawknife, hatchet, machette, brush hook, and even a shovel in moderate soils if need be.
I give it high marks in versitility, which was the original question, I think. But I certainly understand others prefering a different tool. If I intended to cut a lot of wood and were camping from my vehicle, I'd definately take my chainsaw, or precut wood itself. Usually when one thinks of "wilderness", what comes to mind is transport by shank's mare, and light weight multipurpose tools come to mind. I can also understand the perception of poor performance from a tool one is unfamiliar with. Having the patience to learn the ins and outs of the tool makes all the difference in the satisfaction of the user. I also understand the boredom of some with traditional designs, always seeking that latest hi-buck gadget to overcome a lack of skill or knowledge. Afterall, at more than 64 years old, the Woodsman's Pal is no new kid on the block, and is in fact quite long in the tooth.
That said, I almost always carry a 5 1/2" heavy bladed trailing point knife and my EDC stockman. I have dug roots with the knife, speared and twisted a raccoon from a tree, done a mulltitude of fish and wildlife into meat, stirred and eaten supper with that blade in front of a shelter made with the same knife. The knife is an old (circa 1967) Schrade Walden Woodsman 165, but could as well be an old Pal, Marbles Woodcraft or Ideal, a Remington (not a newer chinee), Kinfolks, Cattaraugus, Buck, or Case. It's carbon blade is easy to sharpen, holds an edge well, and the thick spine will throw a shower of sparks like stainless never imagined.
To each his own, I guess. My philosophy is that newer and more expensive is not always better. Quite often, someone got it right years ago!
But then I am just an old ....
Codger
