- May 18, 2005
Write an Acceptance speech?
Great question, I need to go back over some basic thoughts in the OP-
The "same caliber" thing isn't even that- it's a preference for keeping within the same cartridge family. There's a few reasons for this:
1: It doesn't necessarily simplify reloading on all levels, but it does on some. While most of the responses to my reloading focus have been "jarrry Ahern post 500 year apocalypse" - there's also the simple fact that it can be easier to manage reloading at all times if you don't have to stock 3 different primer sizes, any number of bullet types, etc. You do have to adjust things to load different carts in the same family (like .38 versus .357) though.
2: Versatility. If I'm carrying, say, a .38 revolver and a .357 lever gun (or a .44 special and .44mag lever), it's not the same cartridge, but it's the same family. I can keep a half dozen small game handloads that either will accept, for example. and if something did happen, I would be able to use, with decent effect, the pistol ammo in the carbine should I need to. After all, unless soemthing happens to the carbine, it's going to be more used than the pistol if I have it.
3: And this doesn't directly relate to the "same cartridge family" part, but - I like tooling around out here. lots of variable environmental zones, lots of space. Carrying a handgun is not uncommon or unexpected, carrying a rifle isn't, either. I may not always take the rifle out of the truck, but if I do, I want something that's fairly easy to carry and easy shooting. In general, that gets away from heavier and longer hunting rifles, and for ammunition carrying purposes, away from large bore shotguns. Left with carbine type firearms for a preference, focussing on similar cartridge families between the revolver and carbine makes some sense. Looking at the numbers in the first post, it's also obvious that this isn't necessarily just "shooting a longer pistol", either.
Regarding the lever action itself, Chuck Hawkes wrote somewhere that people often compare the lever gun to the bolt action unfairly. Some bolts actions will have a stronger mechanism, but in general the comparison is unfair because people treat their bolt guns like match rifles and their lever guns as saddle rifles. If you polish and tune a lever gun the same way you do a bolt, you will start getting similar levels of performance.
As you may surmise, I would lean toward one of the bigger bores for what I perceive this thread to be about. Probably 44, in order to be able to download more.
This is getting to the core of where I'm getting lost. If you're carrying a lever, then there really is never a reason that you would need to use the revolver, that I can perceive, other than just for fun. Although, if you permit me to go toward the defense against predators scenario, it gives you the option of having the rifle somewhat away from your person while still having the like-calibered weapon on your person. Or, is one system goes down. But unless it is an extended expedition/SHTF issue, if one system goes down, then it's time to leave and head back to the truck. Maybe I just don't have the best imagination.![]()
Snakes are the other main reason. I may sling the lever or pack it while walking up a butte or something and need a fast shot.
To each his own, of course, but I've always thought that if i have time enough to draw down on and shoot a snake, I also have time enough to step aside and avoid it (unless of course I'm planning to put it in the dinner pot).
Hmmm.... well, I used to spend A LOT of time on the trail in Arizona (and a few other desert areas). I still have friends who basically make their career out of walking that same desert. But I certainly agree, water is everything in the desert.
There are lots of different types of "deserts" in the American southwest. Actually, the Great Basin is a diverse place (depending on altitude and availability of water!), and doesn't have a whole lot in common with the southwest's low deserts or many other parts of the Basin and Range.
It is bordered east and west by huge mountain ranges, and there are numerous smaller "island" mountain ranges throughout.....so is isn't just one endless alkali desert! For the most part the mountains are oriented North/South, and it can snow at high altitude, far more than you might imagine! (Think Grand Canyon rim/Flagstaff area, if you are familiar with Arizona.) The insular mountain ranges are very interesting, because they contain species left "stranded" there when the iceage ended and the valleys became hot and dry.
http://www2.hawaii.edu/~khayes/Journal_Club/spring2007/Brown_1971_Amer_Nat.pdf
http://www.nps.gov/grba/planyourvisit/the-great-basin.htm
http://rst.gsfc.nasa.gov/Sect6/Sect6_8.html
http://www.nbii.gov/portal/server.pt?open=512&objID=561&mode=2&in_hi_userid=2&cached=true
Personally, I prefer to do my hiking in the cooler (can be extremely cold!) mountainous regions, and vehicular off-roading at lower altitude which is the more arid/hotter region. Spent a winter once at Barcroft Laboratory which is in the White/Inyo's on the western edge of the Great Basin, when I was young and stupid: http://www.wmrs.edu/
Lief needs a .410.
Look for loads in .44 using very light loads of powder and cast round ball. You can get them VERY light. I had loads for my 45-120 using round balls for rabbits and squirrel.
2Door
Wasn't suggesting it was like the Sonoran, merely that I haven't done all my hunting in Michigan (where Uncle Sam currently has me) as another poster implied (or perhaps I inferred correctly or incorrectly).There are lots of different types of "deserts" in the American southwest. Actually, the Great Basin is a diverse place (depending on altitude and availability of water!), and doesn't have a whole lot in common with the southwest's low deserts or many other parts of the Basin and Range.
I have been to Utah, unfortunately it was for the purpose of burying a brother in arms. Both Utah and Arizona are by and large flat and without significant foliage, but a skilled hunter can still use a "short-range" rifle and bring home game. I say that without suggesting that I would choose a pistol caliber carbine personally. In fact I agree that a flatter shooting rifle would be "better".
Utah isn't as flat and deviod of trees as you think. I've lived here almost 20 years and have seen tons more folage then not. It all depends on the area you are in. Thats why it's said that Utah has such a deverse sellection of flora and fawna.
The tread is about the Carbine in a 3 gun combo that includes a Pistol, Long Range Rifle and Carbine. Pistol on my hip, Carbine acrost the saddle and a Rifle in the boot. Works for me. I just need to get the Rifle to complete my combo.![]()
