Tried to lay these ones out more in line with spine/tang.
Thank you very much for your input. I'll defiently have enough material on ones wrecked today to go for a handle more like that with the hammer.I'll be honest ... I'm not a fan of your handles If you like them, then it's OK, but they look quite "hot in the hand" to me.
On you latest blade, there is a balance between perfectly straight and too curvy. Adding a little drop to the top and a little curve to the top of the handle will improve the look and feel. The bottom one drawn on the bar is far better looking.
There is a tendency to try and get too much from a bar of steel with new makers. Leave room for adding curves and adjusting things once cut out. It would have been wiser to make two good knives instead of the three you drew.
Look at these knives and see how a little curve and "flow" goes a long way. Notice that the handles are plain and very ergonomic. Try making one shaped more like these next time.
View attachment 2976889View attachment 2976891
It should be delivered soon. Ordered that epoxy and 8 pack of steel n sum wolf jaw tongues so can experiment.Looks like you're off to a good start with knife making! I'm no expert but I'm happy to help however I can! Not sure if you've used the West Systems G-flex yet, but while the cost of admission is high compared to a tube of hardware store epoxy, you get a lot more of it and it lasts a lot longer in storage!
Sir I appreciate you beyond words.I will give you the best piece of advice you can get from an old timer who has made thousands of blades, many of them by forging and hardening in a forge.
You can take this advice or not, that is your choice. But, I will tell you that your learning curve will be much smoother and shorter if you do.
Make ONE knife at a time!
When you are new and untrained, you don't know what you don't know. This leads to making errors in judgment on the heat, forging errors, and design errors. Repeating these several times makes you think you learned something, but what you have actually done is made an error part of your methods. By making one knife at a time, you learn to pay attention to the details, and each knife improves from the last. Lastly, Don't rush things. In the excitement of starting to make knives the urge to crank them out as fast as you can is hard to resist, but you should take your time on each and every knife. A rushed knife almost always has many issues when done.
With your setup and methods, my suggestion for you is to use the following procedure for at least the next 10-20 knives:
1) Read up on heat treatment. Get a copy of Dr. Larrin Thomas' book "Knife Engineering." Read it cover to cover.
If the book is unaffordable for you, send me an email or message, and I will have one sent to you.
2) Draw the knife on paper. Cut the profile out in cardboard or scrap thin wood and see how it looks and feels.
3) Cut out that knife shape from your bar of steel (only one blank).
4) Forge it to the shape you picked. Use your cardboard/wood template and drawing to try and keep to the desired shape. When done forging and punching holes (drilling is a far better method), anneal the knife blade. Your setup isn't really good for annealing. Try the method I put at the bottom of this page.
5) Grind in the final profile and bevels, leaving plenty to grind off after HT.
6) Do the HT on a dark day or late in the evening... or at night. You will get a better feel for the color that way.
7) Temper in a kitchen oven or an old toaster oven." Color tempering" is a poor method of tempering knives. (and I have no idea what scraping the edge with a round file has to do with it ???)
8) Finish grinding the blade and take a good look at it when done. Is it like the drawing? Does it look and feel good in your hand (be honest with yourself). If you are happy with it, put the handle on. If not, either modify the shape by grinding a better curve or removing an unnecessary bump. If the shape is such that you don't really like it, set it aside and start the next knife. Many knives from now you might come back and make changes that will work.
9) If all is good with the shape, put on the handle.
10) Sharpen and test the knife by cutting things with it ... rope, cardboard, whittling on a sticks ... then try and cut some paper or a tomato. Did the edge hold up? If so, the HT was good. If it got dull fast, the HT and possibly the forging was not done well.
11) Take what you learned from this knife and start the next one.
Annealing and HT with only a simple forge:
When all you have is a simple and uncontrolled forge, annealing and HT is a problem. There is no way to "soak at 1650° for 30 minutes, etc." or similar processes. The best you can do is try and undo the internal damage to the structures in the steel that formed in forging by cycling and harden it as best you can. This is best done on a dark cloudy day , at dusk, or at night with the lights off. I prefer at night with only enough light around to work safely.
A) Heat the blade to red and let cool in the air to black heat (when the blade is completely black, which is around 800-900°F).
B) Heat again to a little less red and cool to black.
C) Heat until you can barely see a dull red glow and cool to back.
D) Heat until the magnet just stops sticking and immediately quench the entire blade in 120-130°F quenchant. An oil quenchant would be best by far, but if all you can get is brine, use it. Brine will have more blades crack and break, but hardens well.
E) Temper as soon as possible in a kitchen oven at 400°F.
Final comment:
If you are forging a knife, there is no need to cut out a detailed blank. A roughly rectangular blank with a bit of a taper toward the point is all you need. Hammering the hot steel is how you will shape the blade. Forge until it is close to what you want and grind/file/sand in the details. Practicing on scarp metal lying around, or cheap welding metal bars is a good way to learn hammer skills and forge heat control. Most folks try to forge at red, which is too cool. Red is lower than forging temp. The other error is running the forge too hot and burning the steel. The whole blade blank is likely ruined if any of it gets burned/melted.
Fairbertcarl@gmail.com that's my email. Please send an emailSir I appreciate you beyond words.
I'm traveling today. When I get a chance I'll shoot you an email. When I get back in 2 weeks I'll pack a box for you. (I have other folks I need to ship boxes to as
Safe travels. Thanks alot for the advice. May the weather stay awesome on your journey.
