People will say that the Sebenza's S35-VN 58-59 RC heat treat is by design, and advantageous over harder heat treats, because of "ease of sharpening". That argument strikes me as apologist.
Talk about its theoretical advantage all you want but are you really going to freehand sharpen your expensive, precisely made Sebenza on a tiny ceramic rod out in the middle of nowhere just to prove a point about "field sharpening"?
Is the type of person doing the type of tasks requiring frequent "field sharpening" going to be using a Sebenza, a folder with a short blade, tight tolerances, tons of little gaps for dirt to collect in, and a lock type known to be sensitive to dirt and debris? If you do use your Sebenza for such tasks, are you doing so because it's the right tool for the job or so that you can say that you did it? "But it's such a joy to clean and put back together because of the tight tolerances!" Okay, glad you're wasting your time on your camping trip cleaning out your folding knife. Hope you took your set of DMT stones out in the woods too so that you can get a nice clean edge back.
The F&F is so precise on the Sebenza, the attention to quality and appearance is so good, and it is such a boutique item that to say its blade is heat treated very differently from everyone else so that your average everyday user can more easily sharpen it is laughable.
When I hear "ease of sharpening", to me that means "I can pick up a rock and scrape it on my edge, wipe it on my pants and then it's good to go", not "I don't have to make as many passes with the coarse stone on my Edge Pro."
It takes considerable skill and expensive equipment to properly sharpen a V hollow ground blade with a curved edge like the Sebenza's. If you own such equipment and have the time to learn to sharpen a knife, then sharpening steels that are run a little bit harder should be no issue.
At a high hardness S35VN is a solid performer, as demonstrated by the many, many other production knives using this steel, some made by ZT, some by Spyderco, some by Strider and some by Microtech, among many others. There's no need to change the actual steel being used.
