Phillip Patton
- Jul 25, 2005
Here I'm hammering the guard on to make sure it fits and there's no gaps:
Not too bad:
Next I mark what I have to grind off to get the size and shape I want. I use a washer to draw a half round on each end of the guard:
Then grind it to shape. I make my own contact wheels. This one has ball bearings, and is made from pipe.
I have a smaller one that I use for the choil and finger groove on my utility knives that's made with needle bearings. The needle bearings are actually lengths of 1/8" music wire. Cheap, eh?
Here it is all shaped. I like to remove as much material as possible before assembling it with the knife, because the heat generated by grinding can make the epoxy disintegrate...
Here it is with the front (top?) surface polished. Obviously, this must be done before permanently installing the guard on the blade, because the blade will get in the way. Likewise, the ricasso area has to be finished at this point because the guard will get in the way.
Not too bad:
