marrenmiller
Basic Member
- Apr 6, 2017
This may shock a few people I could end up buying two Socom’s![]()
Do it, that's what I did. No regrets.
Your detailed post has been really helpful. Thanks for sharing.Hi guys/gals,
I posted this on reddit a while back and figured you all might enjoy it as well. I recently got some of the new Socom Elites from Microtech, and wanted to compare them to the older 2006 model that I had on hand. I performed a full disassembly on each and was surprised to see how much has changed since the 2006 model, both internally and externally. Feel free to ask questions if there's something I didn't cover.
https://imgur.com/a/7r939
Thanks for the review OP. I have an older Delta model with the clip blade but I also had to go with the new two-tone version that Pinnacle grabbed. Can't wait to get it Monday! I think the clip point version has one of the absolute sexiest profiles ever for a folder.
How thin are these behind the edge compared to the previous models? I recall someone griping that these are pretty thick.
Very trueThey're a lot thicker than the old model, but they're not out of line with their competitors. You have to keep in mind that they're made with 3/16" stock, and medium height grinds, so they're not really designed to be excellent slicers.
Hi guys/gals,
Mine has a very off centered blade and I've tried to center it by adjusting the screws but it didn't make a difference. Is this normal with this knife? Any suggestions on how to fix it?
The closed position stop pin is different, and it's internal within the knife. The thumb studs aren't contacting the handle in the closed position, but only when the knife is open.On the 2018 Socom Elite, the stop pin is used in the closed position and the open position, correct? I noticed in your review (very well done Sir) you referred to it as a "close-position stop pin".
View media item 3929
That's just something that happens to all companies from time to time. They seem to have less of an issue with it than most others do, though.Yes it's a 2018 tanto model. I tried adjusting the pivot but it looks like only one side of the pivot turns so that didn't help. I have many other less expensive knives with centered blades so it's disappointing to have this issue from a company that claims to have the best fit and finish.
Hi guys/gals,
I have heard their CS is better nowadays than in years past, but I can't confirm that.
