Minuteman is already the name of an Old Timer knife.
I was aware of the Old timer knife, Pops has one. While researching the PM2 last night I came across the PM1. It was amazingly a smaller version of the current PM2?
PM2
length overall 8.281 " (210 mm)
blade length 3.438 " (87 mm)
length closed 4.812 " (122 mm)
cutting edge 3.078 " (78 mm)
weight 3.9 oz. (111 g)
blade thickness .141 " (3.5 mm)
PM1
length overall 7.875" (200 mm)
blade length 3.093" (81 mm)
length closed 4.75" (121 mm)
cutting edge 2.938" (75 mm)
weight 3.75 oz (108 g)
blade thickness .156" (4 mm)
Taking a little off the bulb at the bottom of the handle of around .125 to .15" while taking the blade length down .093" to an even 3.00" on the PM1 and were talking perfection. It would technically be a new knife with an ever so slightly steeper grind on the spine of the blade and the small amount off of the bottom of the handle. This would probably make it lighter by a quarter ounce or so, which would be another benefit. You could do this with the PM2 also, you'd just need to take a little more. I'm actually thinking of doing this myself. I'd start with a new PM2 though, leaving my 1st untouched. I've made tools for work from scratch so it wouldn't be my first go at modifying or making something that works for me.
I carry my EDC folders in the change pocket of my jeans mostly. The 4 knives I have are the Delica, Tenacious, Manix 2, and PM2. The Delica has a Lynch deep carry clip and fits perfectly without bottoming out in the pocket. The rest use original clips. The Tenacious doesn't bottom out in the change pocket at 4.45". The Manix 2 fits just perfect at 4.625" being just a hair from bottoming out. The PM2 has to be canted and is the only one that I can consciously feel in that pocket. The PM2 in my regular pockets is a just a little long even there, I don't notice the others in that position at all. It comes in at 4.812", I love it so much that I carry it anyways though. I feel the PM1 (the PM2 would be a little more but it's do-able) with those very slight changes would be a perfect EDC/Work blade. I wouldn't mind the .156" thickness of the PM1 either, it would be a tuff as nails middle sized knife for sure.
Damn, I might have to change my purchase plans for this month and get a second PM2 to play with?
