Thanks.I'm not usually a fan of orange but that is Sweet.![]()
I have a question for knarfeng.
This Manly Wasp originally had a pocket clip, when you order from the U.S. distributor you can ask for a extra plate to cover the clip hole. I didn't know that at the time so I made a plate. In all other respects it is a modern slip joint.
My question is does it qualify as a modern traditional now?
IMG_7165 by GaryWGraley, on Flickr
Untitled by GaryWGraley, on FlickrWhen Gary Graley first brought the Manly Comrade to our attention here in Traditional (and to my pocket, as well), Peregrin-Gary and I said that the knife could be discussed in that thread as long as the clip was not showing. I see no reason why that would not apply to the Wasp. So the Wasp would be OK in this thread.
BTW, which alloy did you get? 12C27 or CPM S90V.
(My Comrade is in the original D2.)
Frank, is that a striker pin (to prevent blade rap) that I see inside the blade well in your last picture? I don't see that mentioned anywhere on the website but yours looks like it has one.Bought a little Boker SFO from an obscure Non-BF seller who does not specialize in knives.
Slip joint
2" drop point hollow ground blade made from 12C27 blade steel hardened to 58-60 HRC.
ORANGE G10 covers held together with Torx screws.
I chose to put this post in this particular thread because this is not really a traditional pattern and because of the orange G10 and torx screws. If you look at the overall outline of the knife in the first picture below, it "looks" like a modern one-hand opening knife design.
Why did I buy? You folks know me. It was the blade steel that caught my interest.
12C27 is reasonable close to 440A in composition and performance (yeah yeah, the chromium content is different. They still perform similarly.) Either one hardened to almost 60 Rockwell is good stuff in my book. Also, Boker makes both purely traditional and modern patterns. So I was interested to see their interpretation of a "modern traditional".
I'm pleased with the knife.
The fit and finish is good. Force required to open is about a 5. Blade is perfectly centered when closed. Came sharp. Nice thin blade. Slices like a little orange demon. But it does "feel" modern and somewhat industrial. I don't have a problem with that. I'm a user, not a collector. But, this is not for everyone.
I put a lanyard on it to help me fish it out of my pocket. I wear industrial cargo pants at work. I can put this in one of the cargo pockets and easily find it when I need it.
Agreed!I'm not usually a fan of orange but that is Sweet.![]()
It appears to be so, to me.
♦ The blade edge does not strike the spring.
♦ There is not much of a kick on the base of the tang.
♦ When I press the back of the closed blade it does not depress and there is no spring movement.
♦ I see marks on the top of the pin similar to what one would expect from the blade tang resting on it.
Son of a gun. I hadn't noticed that detail till you pointed it out.
I think that's another X in the "modern" column.
Cool! Thanks!
Yeah, think l agree, too.I'm glad to see companies trying their hand at modern traditionals and I think the trend will continue.
But
That WE Scamp just isn't checking boxes for me.
