- Feb 11, 2015
It could also be that I don’t know what I’m doing.
Made me laugh out loud..... I need to use that for my signature line.....
It’s probably pretty appropriate for the thread if we spend a lot of time worrying about knowing what we’re doing we wouldn’t be spending as much time modding.Made me laugh out loud..... I need to use that for my signature line.....![]()
I was sharpening some kitchen knives for a local customer and one was a Furi Rachael Ray Santoku. It was a little bit bent so it tried bending it slightly with my hands. Nothing extreme, right? I’m not The Hulk. But this happened:
View attachment 1383595 View attachment 1383596
I tried to call the customer to see if he wanted a replacement knife or just the cost, but I haven’t heard back yet. Have any of you knife makers and modifiers had this happen when straightening a blade?
I know, right!? We have some Corell plates that are very brittle ceramic. They don’t scratch, but if you drop one the wrong way they explode into shards. This knife reminded me of that: it just popped right in half.
That's some horribly brittle stuff, imagine it happened while you were chopping![]()
That was an existing crack in the blade. See how there is the different color at the spine, it was already there, only the lighter stuff is a new break.I was sharpening some kitchen knives for a local customer and one was a Furi Rachael Ray Santoku. It was a little bit bent so it tried bending it slightly with my hands. Nothing extreme, right? I’m not The Hulk. But this happened:
@JTB_5 If it’s a good company it should be a warranty issue.That was an existing crack in the blade. See how there is the different color at the spine, it was already there, only the lighter stuff is a new break.
Was it a quench issue? something during production to have made it so brittle? Once upon a time, I was modding a one arm gec blade and Bob had warned me about affecting the heat treat.
I did a little investigation. FüRI sounds German but of course it's not a German name...Designed in Australia using Japanese steel...made in PRC.
at least you get to see a really nice cross-section of the blade grind...
Go back and watch the old western series "Branded".... might give you some ideas.....![]()
It’s probably from the heat treat, cracked in the quench and then was tempered. My guess is that it wouldn’t have been visible. If you read the warranty stuff for falkniven about broken blades the only way they will cover it is if it has a discoloration like that because they can tell it was a manufacturing defect.I wondered about that discoloration. I'm assuming the coloration is rusting from water seeping into the crack? I wish I'd have examined it a bit closer beforehand. Next time I will be more meticulous.
On closer inspection I can see some of the other hairline fractures on the spine of the knife. It has to be heat treat or later heat damage. It is like the steel was disintegrating.It’s probably from the heat treat, cracked in the quench and then was tempered. My guess is that it wouldn’t have been visible. If you read the warranty stuff for falkniven about broken blades the only way they will cover it is if it has a discoloration like that because they can tell it was a manufacturing defect.
