- Oct 23, 2000
There many differences in the TRACKER knives as they evolved over the years. I had made seven different standard models that were advertized. These varied in length, blade & handle shape. By far, the most popular of my designs which remains to this day, is my "C" model TRACKER. Although the newer versions I began producing again in 2003 were made from the exact pattern I used for "the Hunted" TRACKER knife, there are some significant improvements made to the newer (post 2003) model "C". As seen from the initial pictures posted, the knife I made for "the Hunted" was the older "C" model. These can be distinguished by the obvious hollow ground drawknife edge & non-tapered tang. Most were also boldly stamped with the "TRACKER"
trademark on the left side of the blade. The photo posted of my newer TRACKER/WSK version is from the same pattern but has been improved with a much stronger flat ground drawknife edge. A fully tapered tang was also added to reduce unwanted weight & re-destribute balance to increase performance & improve feel. The newer versions were also differentially hardened & tempered as compared to the earlier knives as used for "the Hunted" which were hardened & tempered evenly over the whole blade.
