Thanks, all.
EmsRescueGuy,
I don't think I'll be adding pages or text specifically to address making a less expensive PSK. However, I'll consider it.
Some less pricy alternatives:
Replace Busse Game Warden with Becker Necker. Replace Pocket Chainsaw with a replacement chainsaw blade. Replace the butane torch with a Bic Mini lighter. Replace the Tinder-Quik with cotton balls smeared with petroleum jelly. Replace the aluminum box with a small baking tin and a piece of sheet metal. Replace the Spectra cord with Nylon cord. Replace the Fisher Space Pen ink cartridge with a Bic pen cartridge, or a small pencil. Get rid of the Trasers and the compact flash card.
I also don't think I'll be adding directions for gear making. I didn't use any pre-existing patterns, and didn't do some brilliant, complex job. I just winged it. For the water bag, I basically cut out two identical rectangular pieces of heat sealable pack cloth, and left long flaps sticking out on each side, on the top. I slipped a buckle through those flaps, folded the flaps over, and ironed them. Then I rolled the top edge once, and ironed the top edge, so it would be double thick. Then I ironed the other three sides of the rectangles, and I was done. For the bivvy, I laid down on a sheet of butcher's paper, and make some marks around me with a marker. Then I used those guide marks, with a little extra room, to create a coffin shaped pattern. Then I drew a pattern onto the fabric from the butcher's paper (two coffin shaped patterns, with one edge touching), cut it out, sewed up three sides and sealed them. Then I sewed a Spectra drawcord into the top, and sealed the seam. Then I copied the hood pattern from the hood of a jacket, made the hood, sewed it on, and sealed the seams.
EmsRescueGuy,
