- Jan 21, 2014
i have a 4max, italian version, as well. i prefer it to the sr1 in someways. its a bigger knife but ergos are better, and doesnt carry all that badly relative to its size and weight.Flushed my new SR1 with warm soapy water and all grittiness disappeared. Smooth pivot and easier to close than some of my earlier Cold Steel models. Great fit and finish. Maybe the knives with the lock rock were a bad batch, and the problem is corrected.
Carried it today with my Recon 1 spearpoint. Two great knives. The SR1 is amazingly overbuilt. But I wonder what I would use a knife for that would require more strength than the Recon 1 provides. Maybe as a solitary camp knife or survival knife the added strength of the SR1 would be handy. Makes me wonder about the 4 Max.
I would like to hold a 4 Max in hand, but not enough to buy one. My local knife shop quit carrying Cold Steel.
Will thin the edge of the SR1 just a bit tomorrow.
Mate, you are one patient man to try reprofile what comes at roughly 25-28 degrees per side down to 15dps with just a sharpmaker. I put my sr1 straight on the KME sharpener with diamond 80 grit stones and it still took a while. Best of luck with it tho, it makes a huge difference once you thin the sr1 down, cuts much betterIt s taking quite a while to thin the edges of the SR1 blade to about 15 degrees per side with my sharp maker cb n rods. Based on the time it is taking , I think the hardness of the s35vn must be relatively high. There is a lot of steel to be removed from this thick blade edge, though. I ll keep working on it.
Mate, you are one patient man to try reprofile what comes at roughly 25-28 degrees per side down to 15dps with just a sharpmaker. I put my sr1 straight on the KME sharpener with diamond 80 grit stones and it still took a while. Best of luck with it tho, it makes a huge difference once you thin the sr1 down, cuts much better![]()
The factory edge angle will be a little different knife to knife depending on who sharpened it at the factory for sure. And wait...No pictures of your new edge??? You should be whipped in the streets!I thought the factory edge was 23-25 degrees per side by my estimate. If the hardness is high , as it appears to be, maybe I m making a mistake bringing the edge to 15 degrees per side. Might be less chippy and still a good cutter at 20 degrees per side. I ve already accomplished the 30 degree total angle now, finally.
It took a long time ,even with the the cbn rods. Finished it with the medium rods and a leather strop. Took me over an hour in 3 sessions. I wondered if I was ever going to get a sharp new edge, but I knew it had to get sharp eventually. Now it is nice.
I might consider putting on a secondary bevel of 20 degrees per side when I sharpen it next.
This folder is the closest I have to a folding fixed blade. Strong.
I m still intrigued by the 4 max. But the extra weight puts me off, for as rarely as I would ever need a folder stronger than the SR1.
yep pushing down on the lockbar solves mine. also riding the thumb stud to open past works as well. it should be noted it isnt aggresive opening that causes it, even slow and steady opening does it, but the ride the thumbstud or push lock bar or pull on blade spine solves it on mine.I have seen a couple Recon 1 reviews where the triad lock had the same problem.
In those cases it was due to the blade rebounding from the stop pin in aggressive opening. When opened by keeping the thumb in the stud, the problem disappeared.
One user diagnosed the problem by pushing down on the lock bar.
Some folks disassemble the knife and polish the lock assembly.
Just a thought.
