- Apr 13, 2007
I don't think it was the pads..... I suspect it was standing water I drove through.![]()
, indeed! What do they make rotors out of, out your way, that they are water-soluble?
Now, see, I heard you didn't have running water there!It must be the standing water. I regularly drive my truck up and down the creek in up to 3 feet of water. I've never had any problems, but then again its running water!![]()
Actually, you're more likely to warp a rotor by getting them (really) hot and then sitting at a prolonged stop, like at a traffic light. The rotor starts to cool, but the area under the pads does not, and it warps.ugh thermal shock is a b*tch...
I may have warped the rotors while pretending I was driving a sports car on a road course (rather than the truck I was actually driving irresponsibly on a public road).........
J, I wasn't trying to re heat treat the rotors...... I was trying to re heat treat the leek blade I had duct taped to the back of the rotor. It turned out that the heat treat wasn't the problem....just the quench at the end![]()
Rotor run out (warped rotors) is a VERY uncommon event. I used to race SCCA, and in many many years, I've never seen a rotor run out due to heat, even at race conditions. More than likely, they've glazed over unevenly(fairly common) , and developed an uneven build up of pad material. You can fix this with fine grit sandpaper. Whenever you change pads, you should "bed them in" with a series of progressivly faster speeds and harder dead stops. You want a micro thin layer of pad on the rotor, but you want it even.
I hope this makes sense!
Bedding pads is where I've seen the warpage occur. People blast down the highway, nail the brakes a few times to heat them up, then pull off the highway and stop.Whenever you change pads, you should "bed them in" with a series ...
This has been a public service announcement; we now return you to your regularly scheduled train wreck.
That picture is directly from ZT's website... check the image properties dood
Hmmm... I remember Thomas saying that, maybe I was having a bad day
lol
oh well..
