Eh, stones work, my mind is simple da blue one is 3k da yellow is 6k, we don't need no stinkin labelsGood to know thanks.
Strange that the 6000# label hasn't come off though.
Hi Shawn
I have read and watched a lot of your posts and videos. But still not sure about what grit to get on Naniwa diamond stones.
Was thinking max to stones to get a good WORKING edge on knives that are in a good condition. That is they are just about not cutting paper in a fluid motion.
Knives that I am going to sharpen:
Malanika 4V on order
Malanika bushcrafter cruwear on order
Spyderco sprig S90V
Reeve S35VN
Bark river jx5 (large heavy chopper) and aurora 3V
Bark river jx6 elmax
(I have waterstones for normal low vanadium carbon steels)
Could you recommend one or two grits on NANIWA diamond stones? Saw that you have 800 and 3000. Feels to fine for working edge or? Thinking 400 and 1000...or?
Thank you!
/Kristian
Sweden
It says for Aussies and Kiwis only.There’s a 400, see Knives and Tools, for example. The 400 is actually really nice, it’s aggressive enough, but not unnecessarily fast cutting. It also doesn’t load, as the higher grits seem to be prone to do.
Thank you for answer.Kristen,
They just make a 600grit. No 400grit.
I'd say get the 800, that is a favorite of mine.
It is difficult to know the jumps.
I bought a 400 and 1000 before your answer. But is that to large jump? (starting to regret not getting 800 instead of 1000).
Thinking of 3000 next and not buy any more![]()
Hi Shawn!
How would you rate the naniwa 800 diamond water stone compare to DMT EF 1200?
I guess if I would make the question more specific... in terms of abrasions rate, polish, feedback and keenness?
If you have something more to ad pls do
I currently own a DMT EF 1200 and wonder if I should open my wallet!Maybe I should ad the stone will mostly touch mid to high-end kitchen knifes.
I would disagree with that. With proper use and care you will get many years out of a 1200 grit dmt.DMT may be a finer grit but the surface finish will be rougher than the Naniwa 800 diamond.
Naniwa makes a better edge.
The Naniwa will last you a lifetime.
The DMT will wear out quickly.
I agree to disagree,I would disagree with that. With proper use and care you will get many years out of a 1200 grit dmt.
They are more evenly graded then the old ones also. You dont need to flatten a dmt plate either.
One last point, a smart shopper can buy 5 dmt 8" plates for the price of 1 naniwa.
"Better" edge...? Perhaps... Just some other views from an old dmt user.
Russ
Russ
The surface finish is less rough, better for push cutting, they function better with hard steels. Softer steels load them faster.My guess is the best application for the diamond waterestones is for wide beveled Japanese culinary knives and possibly woodworking tools with wide bevels. Neither of these are very fun to work with on plated diamonds.
That said I am not enamored of the handling qualities of my diamond waterstones from JKI. They cut slowly for their rated grit, load rapidly, and the edge quality is not exceptional compared to a plate or (with non-super steels) any of my other waterstones. I have no experience with the Naniwa, but the JKI ones seem like a niche tool where you might want a softer touch and diamond abrasive. In that case comparing them to diamond lapping film might be a better analog.
This is why I like Vitrified, it cuts faster and loading doesn't slow down the cutting or effectiveness, but price is high.
Those resin stones from JKI will last a lifetime. The plates will not.
I still own and use plate because they make a micro serration for when I want more aggressive draw cuts at consequence to cleaner, better push cuts.
It's an inverse relationship.
