Hard to argue with that! Just about all the high center I'd want on an all-around axe.
I'm still hoping to see them come out with a rafting pattern. Or a Connecticut.
The sheath carry system is a nice try but a little off in my opinion. If an axe is to be carried upside down then I want the head to slip into the sheath from the bottom not the top. It is easier and safer to remove that way without taking off the sling. That is the way they were made in the past, but I wonder if they even looked at that. And the Velcro was a horrific idea. Who mixes leather and Velcro? That piece should just be a loop of leather. There is no reason to have it tightly wrapped around the handle at that point, all it does is hold the handle against your back in an upright position.
Are these the same handles that are on some of the other Council axes? They look pretty good and 24" handles are getting harder to find. Hopefully they will sell replacements.
The axe pictured on this thread shows a wood center wedge. The CT website says an aluminum wedge is used. Which type will the mass produced axes utilize?
I think this is a smart move by Council. In this they bring back home an important segment of the axe market. For years the small bushcraft/survival axe market has been dominated by imports. It's good to see Council competing for that market.
I think this is something they should look at - bringing back some classic American patterns and making them with top notch steel and geometry. A hardened poll rafting/miners/construction axe would be nice but let's face it, the market for that axe will be much less then what they're offering here.
Axe aficionados like those who frequent this forum would want one but the general public wouldn't understand or appreciate what it is.
A Connecticut pattern might sell.
For myself, I'm with Benjamin that I'd most like to see a rafter with hardened poll. I'm just not sure if the market is ready for that.
Oh, and it might be smart to start making a saddle axe. I think they'd sell well.
The phantom bevel at the front extends down awfully low. Anyone aggressively sharpening this axe more than a 1/2 dozen times will run out of blade! Otherwise I'm glad to see the Swedes come into some competition.
The sheath is a upgraded version from the sheaths that they offer for their Hudson Bay axes...The sheath is made to be carried (as an option) on a belt with larger slits on the back to accommodate an even larger work belt.
The axe can easily be removed from the mask/sling without the user taking it off of their body.
The sling is not leather but made out of Boithane, which is a rubber coated nylon webbing that is often a replacement for leather in horse driving and riding lines and other tack which often sees a lot of wear and abuse.
The velcro is actually very heavy duty, and by using it somewhat tight it is a back up, if the snapped cover were to unsnap. It is adjustable and easily replaced or changed to leather if the user chooses to do so himself.
The sling was designed to be heavy duty, weather resistant, low maintenance, and usable on other axe sheaths and axe sizes in the future...and with it being and added accessory it gives the consumer a choice to purchase with or at a later date....I'm sure there will be a host of aftermarket leather guys that will be offering leather options and adding their own flare...
I hope I was able to respond to some of your concerns...
Peace, Rooster
Thanks for your detailed response. The Velcro makes more sense if the sheath is not leather. It is certainly a better looking rig than what is usually available for new commercially made axes.
I'd prefer no phantom bevels--everything else looks good to me. I can't see any practical purpose for the bevels on the 19" model and it limits it's usefulness as a carpenter's hatchet to fashion things. Perhaps on the 24" for splitting though its still not my preference.
How much do you take off per sharpening?I do agree it comes down pretty low, but that actually allows it to DO something during chopping. A lot of phantom bevels are effectively cosmetic unless being used for splitting work. Even once you work past the thicker edge region you'd just have a thin body to the heel and toe, but that doesn't mean you would have to change your actual edge angle--it'd just change the visual bevel width due to the reduction in thickness.
