Alright lets start brainstorming about how this steel might preform... because I have no idea how Hap 40 performs in terms of ease of sharpening, wear resistance, toughness, and stain resistance... school me lol![]()
Cobalt increases hardness not decreases it...HAP40 = CPM Rex 45 = (CPM M4 + 8% cobalt)
http://www.zknives.com/knives/steels/steelgraph.php?nm=hap40,cpm m4,cpm rex 45&hrn=1&gm=0
I say equals because the composition is close enough to be the same within the margin of error you'd get in steel production - I really doubt anyone would be able to tell the difference between HAP40 and CPM Rex 45 without a spectrometer.
Spec sheet: https://www.alphaknifesupply.com/Pictures/Info/Steel/CPMRex45-DS.pdf
Based on that, adding the cobalt lowers both the toughness and hardness by a small amount. In exchange, you get red hardness (the ability to withstand stress at very high temperatures) and likely some corrosion resistance. The cobalt may help with sharpenability only in that it's reducing the overall hardness. Overall, based on the specs, I'd say it's similar to M4 but not quite as good.
It seems to me that Spyderco loves to run their steels harder than most other manufacturers. I think its part of what makes them perform so well
What?It's going to depend on how spyderco does the heat treat to see how it performs... if they do it right it should be very similar to good Hap40 and better edge retention and toughness than M4. The reason i say good Hap40 is cause the Hap40 delicas weren't done well... you need to go to a higher hardness on it and Rex 45 to make it work well
Guess i worded it wrong... spyderco didnt do as high of a HRC on the hap40 sprint runs as they should have to get the nost out of it. I was saying that if they dont make that same mistake and run the Rex 45 to a higher HRC it should be really good... if they dont it will be beaten by the m4 version of the military easy in almost every way.What?
The thing is tho is that spyderco didnt get all they could out of their hap40... it needs to be a higher hrc to get the full benefit from having the cobalt which allows a higher hrc without giving up much toughness and sharpenabilityIf this is really an American analog of HAP40 then I think we will see comparable performance, which isn't all that impressive compared to M4.
In Cedric Ada's tests, HAP40 did well but not outstanding and not as well as many thought. This is of course one one parameter (wear resistance) but is worthy of note. M4 seems to make excellent use of it's proportionally lower carbide fractions (I believe around 12%?) much like Cruwear/PD1 does. These steel outperform many much higher carbide steels (like S90V).
I don't get the appeal of another HSS when we have already had the same models in M4. Also, orange is hideous.
I'll keep my experimentation to the VToku Endura I just got, a low alloy tungsten steel is something I haven't had before.
Off topic, how do you like the Vtoku and do you think it compares favorably with superblue? I’m waiting for a stretch2, but don’t know when or whether yet.
In this case that test means nothing..the Hap 40 series wasn't even close to 66.5 rc..66.5 will change things and could change them a lot..remember the rc hardness scale is not linear and even 1 or 2 points makes a big difference.If this is really an American analog of HAP40 then I think we will see comparable performance, which isn't all that impressive compared to M4.
Yea thats what I've thought to... the spyderco hap40 has been lack luster but ive had other hap40 knives that seem to hold an edge forever... which i hope the Rex45 will as wellIn this case that test means nothing..the Hap 40 series wasn't even close to 66.5 rc..66.5 will change things and could change them a lot..remember the rc hardness scale is not linear and even 1 or 2 points makes a big difference.
We can speculate forever but we wont know until they are in hand and used/tested.
