If I may make a suggestion- and I know these tests are time consuming- but what if you tested the same knife, same steel, several different times? Not just once or twice, but 15-20 times? If your results are all generally the same, then it will throw some more credibility at the tests in my opinion. But let's say you're off on a few of the trials, it might show you and us that the individual tests could be very wrong. For example let's say you test Kershaw 13C26 and your end weights are: 70-80-75-70-80-120-70-85-75-80-30-75-80 Then you would have to at least realize that even a small mistake can throw your tests off drastically even with the same exact knife. Especially if you get results like:
70-80-20-125-65-90-35-200-75-90-110-60
I like your testing method and it seems refined. But there could be one thing that is throwing the whole thing off, and you can't find that out until you try the same knife not once, twice, or thrice, but multiple, multiple times.
Most of these discrepancies are already somewhat ruled out because your weight constantly goes up, and usually it goes up gradually. It all seems pretty consistent, yet you do the tests consecutively with the same knife. For ex:
INFI 420 ATS FF LAU S60 S30 BG INFI
000 040 030 040 020 020 020 020 020 020
001 060 050 060 030 020 040 030 020 030
002 070 050 070 040 030 040 030 030 040
003 070 060 070 040 030 040 030 040 040
004 080 050 070 040 040 040 040 040 050
005 080 060 070 040 040 050 050 040 060
006 080 060 070 040 050 060 050 040 050
007 --- 070 080 040 050 060 060 040 050
008 080 080 080 040 050 060 060 040 060
009 --- 070 080 050 050 060 060 040 050
010 070 070 080 040 050 060 060 040 050
012 080 070 080 050 050 060 060 040 050
015 080 080 090 050 050 060 060 050 060
020 080 070 090 050 050 060 060 050 XXX
025 080 080 090 050 050 060 060 060
030 090 080 090 050 060 060 060 060
035 090 080 090 050 060 060 070 060
040 090 090 090 060 060 060 070 070
045 090 070 090 060 060 060 070 070
050 080 080 090 060 060 060 070 070
060 090 070 090 060 060 070 080 070
070 --- 080 090 060 060 060 080 070
080 100 080 090 070 070 060 080 070
090 110 080 --- 070 070 060 080 070
100 110 080 090 070 070 060 080 080
110 110 080 090 070 070 060 080 080
120 110 090 090 080 070 060 080 080
130 110 090 090 070 070 070 080 080
140 100 080 090 080 070 060 080 080
150 110 090 100 090 070 060 080 080
160 110 100 100 100 080 060 080 080
170 120 110 100 090 080 060 080 080
180 120 110 100 080 080 060 080 080
190 120 110 100 080 080 060 080 080
200 130 100 100 090 080 060 080 090
210 120 110 100 090 080 060 080 090
220 130 110 110 080 080 060 080 090
230 110 --- 110 090 080 060 080 090
240 110 130 110 090 080 070 080 090
250 110 130 110 100 080 060 080 090
260 110 130 110 100 090 070 080 090
270 110 140 110 100 090 070 080 090
280 110 130 110 100 090 070 090 090
300 110 140 110 090 090 070 090 090
320 110 140 120 100 090 070 090 090
340 120 150 120 100 100 070 090 090
360 120 140 120 110 100 070 090 090
380 120 140 120 110 100 070 090 090
400 120 140 130 110 100 070 090 090
420 110 140 130 110 100 070 090 090
440 110 140 130 110 100 070 090 090
460 110 150 130 110 100 070 090 100
480 110 160 130 110 100 070 090 100
500 110 170 130 110 100 080 090 100
520 120 170 130 110 110 070 090 100
540 120 170 130 110 110 080 090 100
560 120 180 140 110 110 080 090 100
580 120 190 140 110 110 080 090 100
600 120 200 140 110 110
650 130 230 140 110 110
700 130 260 140 120 110
750 130 --- 150 120 110
800 130 --- 150 120 110
All your values go up gradually. That proves the indivdual test itself is mostly consistent. But you always test the same knife consistently on the same day. If you tested one knife over a span of a week, you might find out things like humidity, temperature, and cutting medium inconsistencies can all affect your results greatly. Plus, we won't really argue if we see you did the same knife over and over about inconsistencies in the knife.
