- May 16, 2006
Please notice that results are better not worse, so it is not some random variations but exactly adaptation.
Well at least in this case it got better
Not surprising, this is what I found when I started doing systematic testing ... not only my sharpening skills, but even just my skill using a knife for these kinds of controlled tasks improved significantly.Results are different, so somehow I adopted to testing and start doing it better - one way or another - this need to be analyzed. Is it way I test sharpness, or the way I cut rope - I do not know. But this adoptation need to be somehow accounted. So I can not directly compare old and new results. I guess it should not be much difference in results of the tests done at same time, but defenetly I can not compare recent test with month and a half old.
I just finished retest:
Yuna Hard II ZDP-189 (10 Oct 2008, 1 Dec 2008)
CUT
000 010 010
001 015 015
003 025 020
006 040 020
010 040 030
015 040 025
020 055 030
030 055 030
040 055 040
060 055 050
080 050 045
100 055 050
150 065 045
200 080 050
I think I need to test Yuna Hard II few more times and then analyze what I will get. Or may be I should retest Sandvic and then Yuna again - having them be retested several times and see what results will look like.
Thanks, Vassili.
This is why IMO it's essential to have at least a couple "reference blades" that get used in every round of testing. At least you then have some meaningful point(s) of comparison. But yeah, the actual numbers being generated have no absolute value.It's a lot of work doing tests like you are doing. And for that, a :thumbup: But I do wonder whether the results aren't almost completely random. The differences between the old test and this new one are enormous. I wonder if there would again be great differences if you did a third test. Variations like this do raise serious questions about whether there's any real validity in this type of testing where a large human factor exists.
Hi Vassili.
I wonder how much the edge angle is influencing the results. I have found that many steels do not hold a 30 degree edge very well. Is there any chance that you would be able to retest a few of the knives with a 40 degree edge angle from a Sharpmaker?
I know this is a lot of work!
Either way, thank you for your efforts.
Frank
This topic is fascinating to me, and I cant thank Vassili enough for his time and thought put into his work.
As an engineer I have always considered what testing methodology could be developed to give as meaningful results in this area.
Vassilis is as well thought out as any I have seen; though the lack of repeatable results always puts any conclusions into question.
One thing I can add is that through my own real world knife usage, cutting a variety of materials on the job site and when hunting/camping, Bob Doziers D2 does seem to offer better edge retention then any other steel I have used.
Keep up the good work Vassili; I look forward to seeing what you come up with down the line.
And for the rest of us, Vassili has set the bar pretty high; we should all strive for such a scientific approach to our own testing.
"If you're not living on the edge, you're taking up too much space."
Big Mike
