- Dec 5, 2008
How about having the thread fixed on one end, and have a weight hanging from the other to create tension?
I agree completely, Phil, and expanding on what you're saying, IMO this is critical to take into account during sharpening as well. When using a device such as a Sharpmaker the force being applied to the edge can be huge, and the finest edge can only be achieved by using the lightest pressure.Broos, and others.... If you think about how little material supports a micron dimension fine edge and the volume of steel that is resisting the deformation (strain) and make some simple calculations then it is pretty obvious that the edge can fail either by bending or breaking with very little cutting force. This is a combination of compressive and tensile loads. If the cutting force is exactly down with no side loads then the edge is in pure compression. It can take a lot of force in this condition. As soon as a little side load or twisting (when the tester gets tired or loosed concentration) is applied then that is when I think failure happens.
In any case an edge at 60 RC will have a strength of about 400,000 psi. The smaller the area the larger the stress so even with a little side load the strength is easily exceeded. What this means is that the sharper the edge the weaker it is. A "hair whittling) edge is not the optimum for cutting rope. A reason why sometimes results are over the map. I applaud Nozh for his work. He must have a very sore hand and wrist. I again have to go back to the premise the this is a test of knives, not steel. Yes you can get some rough ideas on wear resistance between steels but there are so many other variables that it tends to get lost. Hardness equals strength so unless we know the hardness of each blade then its hard to make good comprarisons. Here are some other variables that make a difference:
Blade shape-- A curved blade will cut better and longer than a flat one. The belly concentrates the force on the rope fibers so can cut with force and less wear over the long run.
Length of cut-- A longer slice distributes the force over more edge therefore less wear in any one place.
Hardness-- all ready discussed
Edge shape-- Flat grind is a wedge. A thinner wedge has a better mechanical advantage and less friction (drag). Hollow grind will drag on the flat to hollow transition.
Blade finish-- better finish has less drag.
A push cut-- causes less wear than a slice. So when cutting it is critical to get the same relation between a push and slice each time the rope is cut.
Some of these have more effect cuttting against a scale. But maybe helps to put some of this into perspective..... PHIL
Vassilli, I was responding to Broos who brought up a point about edge deformation. Didn't mean to leave you out of the discussion. After all it is your thread to start. I was also attempting to explain why a blade can cut different from test to test and also why it could loose edge and then restore itself. We have different test procedures and yes I agree that with large differences in performance you can draw conclusions about how knives will behave. I think we have to be carefull drawing conclusions on how steels (not knives) will perform based on a couple of tests. I agree Dozier's D2 knives are great perfomers. He does a great heat treat and I would bet that his D2 is close to RC 61/62 based on the results of your testing. I would offer also that his edge geometry, blade finish, and ergonomics also play a major role. From your test on his knife I humbly submitt that you can't say that D2 is always going to have better performance than say CPM S30V or 10V for example. Yes I think that all the factors do influence the result. We do not know the hardness of the AUS8 blade you tested. I would guess about RC 58. If it was pushed up to say 60 and the blade thinned down to .008 inch or so behind the edge then I would bet you would have much different performance. I would agree that Aus8 in general would not perform as good as Dozier's knife in D2. This is mostly cause Bob does not work with AUS8. Anyhow some things to think about. By the way Vassilli where in California do you live? I am about 3 hours from the Bay Area. Maybe we could do a cut a thon sometime..... PHIL
I have finished several simple knives, all the excact same in grind, edge ect. Steels are: CPM 125V, CPM 10V, CPM 90V, CPM 30V, CPM 154. I plan to do 154 CM, D2 and AEB-L as well. All are, will be, known hardness. Testing so far with my method shows that they fall pretty much in the order I have them listed above. What is interesting so far is that given the optimum heat treat, (at least I think so) that 90V, 30V and CPM 154 are grouping into a similair category. I will post more on this later... Phil
I've done some backyard testing over the years and found that for me even the difference in handle comfort made a pretty large difference in results. I do find all testing very interesting and intertaining. I've just come to beleive that almost all of the so called tests are more subjective than any kind of fact or proof of anything.
Vassilli, My objective in testing is to predict how a knife is going to act in a real world situation.
You mentioned one time the differences in the number of cuts we get. I recall that you cut ½ , but remember I cut 5/8. That would explain the difference.
I don’t sharpen to a very fine edge. I use the knife as it comes off the fine SC Norton or green DMT stone with just a few strokes on a loaded strop to take off the burr. Final edge angle depends on the thickness behind the edge but will be 17 to 25 degrees in most applications. I don’t know what a hair whittling edge is so can’t compare that to what mine is. I was trying to make the point earlier that the sharper an edge is the weaker it is. If an edge is fine enough to whittle hair then for sure it is going to bend, bend back, roll, fracture --or all of those-- with 20-30 pounds force cutting very tough rope. Seems like when cutting the string it is possible that you might be in an area of the edge that is damaged. I was suggesting that for some of the knives you tested that this could explain some of the data you got. In my cutting method I think I am minimizing this effect by a steeper edge angle and the fact that it just shows up as differences in force needed to slice the rope. It all averages out. This is OK or not depending on what your objective is. One thought to consider. How about a thicker string and a longer cutting stroke for the sharpness test?
Another thing that might be interesting is to measure the force needed at the start and after you finish the 200 cuts. This would give an overall feel for the cutting efficiency of the knife. It would probably take about 10 slices for each to see where you are on the scale.
Your suggestion to me, to measure sharpness before I start is a good one. Right now I do this by the scale reading or by the feel of the edge with my thumb. I need to think about how to do this with more precision-- mostly for credibility.
I have to come back again to the premise that we are testing knives. I do not think you accept this. You can draw some conclusions about steel but all of the knife characteristics come into play to tend to wash out the steel conclusions. Hardness for example can make a huge difference. I have found that CPM 10V at 62 and CPM10V at 64 act like two different steels. My cutting work has convinced me that steel comparisons can only be made with identical knives but different steels. I tried to make this point in previous posts here. If you do accept the premise that we are testing knives then testing a folder against a hunter is not a fair comparison for a lot of reasons.
I recently had the opportunity to do some extensive field testing on a Bison hunt. My objective was to correlate the results in the field to my rope testing at home in the shop. In short I found that there is a pretty good correlation. In other words if you can get x number of cuts with y force with a given knife and sharpness then it will do the expected job. I am writing up this experience and hope to get it up on my web site early in 2009. Vassilli, I admire you for your scope of work and the effort involved. I have learned some things and has forced me to think through others. Different people test for different reasons. Keep it up-- and again where are you in Ca. ? send me a PM if you want but would be interesting to get together and collaborate on some of this. PHIL
