add a 75 to 100 shot of NOS,
Adding nitrous oxide injection to a bone stock truck is a terrible idea, especially a 75hp to 100hp shot of NOS (NOS is a company, the gas used is called nitrous oxide or NO2)
There are also 3 different types of nitrous injection.
Dry-the NO2 is simply sprayed into the air intake. Since the gas is cold, the mass air flow sensor tries to add more fuel. This may or may not result in a good A/F mix and will definitely run lean over 50hp shot or so. Doing a 75 to 100hp shot would most likely ruin the engine
Wet-The nitrous is mixed with fuel and then sprayed. This negates the fuel problem and allows you to run the same fuel map whether or not you are using nitrous. This is much more expensive and requires modifying the fuel rails. Here a 75 or 100hp shot could be used, but may need other modifications (I am not an expert on modifying Tundras)
The final type is direct injection but that is much too expensive.
Also the typical way to trigger the nitrous is through a sensor which can tell when the accelerator is a pushed all the way down. The Tundra has a drive-by-wire system and doing this could result in nitrous being injected into the manifold while the throttle is closed due to the truck shifting gears. This may result in a detonation or other engine damage.
But you knew all that right?
The typical modifications to look at first are ECU/fuel map, exhaust, intake and then go from there.
