I prefer the construction where you screw into threaded standoffs from both sides of the scales. Screwing into the standoffs from both sides allows me to only unscrew one side, leaving the standoffs securely screwed into place, to take the knife apart. This eliminates the issue that I sometimes have of my spacers moving around and not being in the exact right place when I'm reassembling the knife.
I hope moving forward that ZT uses the construction technique of screwing into the standoffs from both sides.
How is that obvious?
Have you machined titanium?
Have you seen how bloody cheap stand-offs are to buy?
I've done both.
Obviously whoever designed the knife wants it that way it is.
Obviously some people here don't like how it looks.
Obviously, they should buy a different knife.![]()
It's obvious because it cheapened the knife, in cost...
Can you explain how you know this to be true?
........In the case of the 0450cf (which has this design with aluminum standoffs), I would theorize that using a single screw would add more support between the mating surfaces. With 2 screws, you essentially have 2 surfaces that are joined with 2 separate supports (screws), and with one screw you have 2 surfaces joined by 1 solid support. Imagine a pair of scissors where the handle and blade are divided into 2 separate pieces at the fulcrum rather than 1 solid piece.
Strictly opinion. Should I go back and add "IMO"?
So it's your "opinion" that this type of construction (as opposed to having screws on both sides) is cheaper, but you have no articulable basis for your opinion? And yet it's also obvious? Maybe instead of going back and adding "IMO" you should go back and replace your post with "I'm sorry for wasting your time."
The lock side dies look cleaner and smoother without screw heads. Maybe thats what the designer wanted. Also that is a very small area to have a screw head. Another down side to this type of construction is you have less ajustable play on the scales to get everything centered if need be.
This raises an interesting question, one which I have pondered recently. Consider the construction method noted above in comparison to this:
I have a knife with a G-10 2/3-length backspacer. There are three screws on each side of the handle for six total. All are secured through the handle into the tapped backspacer.
These screws are not aligned with one another on each side, but staggered in alignment, securing backspacer to handle in six places (each going through the G-10 of the handle and a titanium liner into the backspacer), from midway up the handle where the backspacer begins, back to the rear of the handle.
Considering both types of construction on knives of the same size, on one knife it would be three screws, all the way through to the other tapped handle as in the quoted example. The other would be my knife, still with three screws on each side, but staggered providing six individual attachments to the backspacer, three from each side.
Realizing one is held by six screws, the other by three, it's still a net result of three holes on each side of the knife. The difference being alignment where the three screws of one go straight through, the six screws of the other are staggered.
I'd be interested in opinions as to which would make a stronger, more preferable, rigid construction.
They might be in seperate locations so that the screws don't run into eachother.
Regarding a rigid construction:
For example: let's say you have a knife with a backspacer that is held with 6 screws (3 on both sides). If said knife had any small amount of play within the screws/backspacer, then each side (scale) of the knife would move independently and in theory would "misalign" the entire knife (possibly an unnoticable amount). This would also hold true for a knife with 3 screws on each side, but with the taps in 6 different sections.
-If there is play within the screws, both scales will move independently
-If there is play within the backspacer, both scales will move independently
Now with the single-screw design (like the ZT's), if there is any small amount of play within the screws/backspacer, the scales would act as one since they are held with the same screw.
-If there is play within the backspacer, only the backspacer will move
I talked to a custom knife maker a while ago, and I was told that a backspacer is much harder to "do right" rather than standoffs. The backspacer has more surface area that needs to be "true" against its mating surfaces.
I never had the desire to machine ti
