This is my primary concern with giving a yay or nay to hardness when heat treat is outsourced--if done at home, I can trouble shoot issues, but without knowing exactly was done by a second party, I'm unable to say for certain why some issues happen. Last month for example a HT provider was skipping foil or anti-decarb compound, preheat, snap temper; and on top of those cryoing straight from plates by literally tossing them into a cooler with 200% ETOH, which naturally resulted in a much lower as quenched hardness and then severe warping issues--worse, he lied to the client. Were it not for the fact pics clearly showed heavy decarb, we wouldn't have known something was up.
In another instance, a HT provider sent knives back to a client labeled as 61Rc, and while the blade did RC at 61, the tang was a solid 64+, which is very much confusing and alarming as the unknown method for differentially tempering may have caused some of the client's issues.
The good news is NJSB and I are still working on more conclusive testing with the foundry to pinpoint potential possible issues or more clearly define heat treat schedules for better edge stability when ground thinner. I'm particularly debating increasing phosphorous in later reiterations of the formula.
Timos, miss you bud, noticed you'd ghosted from FB although I keep up on you via IG. Dunno if I'll be posting projects here, I'm here mostly as NJSB liaison and tech support, and I kinda sorta did promise Stacy I'd behave
