- Nov 10, 2011
has anyone compared it to Sandvik 14C28N which has almost the same composition?
Not too soft. I usually do my nitro-v and aeb-l field blades in the 59-60 range.I plan on using Nitro V for a "mini kukri with a 5 inch blade and for 6 to 8, 3-4 inch bladed knives . I want a balance of toughness and edge holding for them.
I send all my knives to Peters, just need a hardness or hardness range.
What should i have them hardened too.
I was thinking 60-61HRC but not sure if thats too soft.
Thanks! I'll probably shoot for 60 then.Not too soft. I usually do my nitro-v and aeb-l field blades in the 59-60 range.
While Nitro-V is an improvement in corrosion resistance over AEB-L, it is unlikely to have superior edge retention.It’s sounding like nitro v will have a little better edge retention?
Thanks for the reply Larrin! That answers my main question.While Nitro-V is an improvement in corrosion resistance over AEB-L, it is unlikely to have superior edge retention.
Why?While Nitro-V is an improvement in corrosion resistance over AEB-L, it is unlikely to have superior edge retention.
Because the calculated carbide volume is somewhat lower.Why?
I'm working on a Nitro V batch.
I know your the aebl expert so I'm curious.
Not trying to argue, but if you could bring us up to speed I'd appreciate it.Because the calculated carbide volume is somewhat lower.
Nitro-V is basically AEB-L with a Nitrogen and Vanadium addition. From the thermodynamic calculations it appears that the increased nitrogen leads to less chromium carbide for a slightly reduced volume of carbide. However, even if those calculations are inaccurate the carbide volume would then be unchanged for no improvement in wear resistance. The claim given for an improvement in wear resistance seems to be because of the vanadium addition; however, that amount of vanadium is so small that it is unlikely that any vanadium carbides or nitrides are present after heat treatment.But how? It's got more alloy
Thanks brother, I appreciate that.Nitro-V is basically AEB-L with a Nitrogen and Vanadium addition. From the thermodynamic calculations it appears that the increased nitrogen leads to less chromium carbide for a slightly reduced volume of carbide. However, even if those calculations are inaccurate the carbide volume would then be unchanged for no improvement in wear resistance. The claim given for an improvement in wear resistance seems to be because of the vanadium addition; however, that amount of vanadium is so small that it is unlikely that any vanadium carbides or nitrides are present after heat treatment.
I don't like to give specific advice for individual applications and knives. I don't know how the knife will be used and I don't have enough data on how that specific geometry behaves. Even if we limited it only to the steel behavior I've never done a set of experiments on NitroV and how its toughness changes with different hardness and heat treating variables. Test it out and let us know!Larrin,
I'm planning a run of kitchen knives made of nitro V. They will be .10 at the spine, hollow grind to .005 at the edge, and sharpened at 10 dps. Would Rc 63 be too hard for them?
Tim
If advertising was consistent or accurate maybe we could better critique their claims.I was under the impression that the higher *achievable RC hardness of RC 63-64 allowed for better "wear resistance" with he Nitro-V. In addition, even at that hardness it was still as stable as the AEBL at RC 62.
...I have yet to test that theory in full. So far the only nitro V I have tried at RC64 was more chippy than AEBL but the blades were bent a bit and it was a new heat treat guy "for me". I do have some Rc 64 nitro V back now from a different heat treater (the same that does my aebl)....so I can test those blades soon.
