NJBillK
Custom Leather and Fixed Blade modifications.
- Mar 27, 2014
Based upon sheer estimation, do you perceive any benefits or detrimental differences between the two, warranting the use of one more so that the other?Nitro-V is basically AEB-L with a Nitrogen and Vanadium addition. From the thermodynamic calculations it appears that the increased nitrogen leads to less chromium carbide for a slightly reduced volume of carbide. However, even if those calculations are inaccurate the carbide volume would then be unchanged for no improvement in wear resistance. The claim given for an improvement in wear resistance seems to be because of the vanadium addition; however, that amount of vanadium is so small that it is unlikely that any vanadium carbides or nitrides are present after heat treatment.
If not more so, do you see one fulfilling a particular role better than the other?
I saw this past of yours after I had posted. If you think this about covets by question, that would be fine. Though anything more would also be appreciated.
----I don't like to give specific advice for individual applications and knives. I don't know how the knife will be used and I don't have enough data on how that specific geometry behaves. Even if we limited it only to the steel behavior I've never done a set of experiments on NitroV and how its toughness changes with different hardness and heat treating variables. Test it out and let us know!
Edited due to autocorrect being the bane of my OCD...
