I don't think so.....nozh2002 said:Do not make box. Have rather 4 separate screens.
Box just limit you ability.
SharpByCoop said:I don't think so.....![]()
Vasilli, Joss is making a 'tent' and not a true 'box'. With the angled back of the upper diffuser and reflectors from the front side, you can get 90% of the typical lighting needs met. You have a different setup and your work is great. But I think your own setup is more limiting, if I understand it correctly. Photo???
Joss, dimensions aren't all that critical. Having the ability to move those lights around in the back a bit is more crucial. Keep going.
Coop
SharpByCoop said:When I am satisfied with the image and processing, then I save it once at level 11 compression in Photoshop as a JPG. The image if flattened and all the layers, text, borders, etc are one part of the image with no layers. (I could not see or print any distinction saving at 12 over 11, but the filesize doubled. I dare you to do the same comparison and look for the differences.)
They're not incandescent bulbs.mete said:The plastic garbage bag might not stand the heat of incandescents.
