- Mar 3, 2013
Here's that old related thread from about two years ago: 810 Contego backspacer fracture
Who is arguing that? Certainly not I.
I only took issue with someone saying that the Contego was worthless as a hard use knife because of this design flaw. You should never plan on dropping your knife, regardless of whether it's built to take it. Using it hard does not equal dropping it. Using it hard includes only the use of the blade for hard cutting tasks. So it's a perfectly capable hard use knife as long as you don't drop it on a hard surface (which should be avoided anyway regardless of the knife). Whether or not it breaks when dropped is irrelevant when talking about the knife's hard use capabilities.
If one of the more relevant parts of the knife such as the blade, lock, handle, stop pin, pivot, etc were breaking when you were trying to cut something, then there might be a case for calling the Contego a poor excuse for a hard use knife.
Remember, the issues reported on forums are a small percentage of extant issues.
I could hand you any number of folders and watch you drop them on the floor all day with no problems.
Some, you could do that on tile, or concrete no problems.
I can't count the number of times I have dropped folders on concrete!
I have more than a few beat up folders that have all sorts of nicks and dings!
I carried and used 1 folder every day for 15 years. Dropped it to concrete and metal surfaces dozens of times, sometimes tip first. Nothing ever broke.
Coincidently, it's a benchmade black class.
pbcg said:I've dropped my knife on steel metal decks without breakage. It was a BM Black class too. Benchmade sure does make some strong knives!
No one's saying Benchmade Black Class has an issue. Some of the best knives I have owned were Benchmade Black / Blue Class. This is about the Contego in particular.
I am somewhat surprised at the rationalizations that have popped up in this thread. Yes, Benchmade makes a good product. No, breaking when dropped is not acceptable for a "hard use" knife. I have droppped Buck knives (with a significantly lower price point) all over the place with no more than a scratch. No, I didn't "plan" to drop the knife, but in the real world "stuff" happens. Also, if you need to replace a part with an aftermarket piece to ensure the knife will not break then the manufacturer needed to do so when they designed it.
Just my $.02.
But we have a few reports, and I stress "few" reports of a back spacer breaking and all of a sudden the knife isn't up to speed or sub par?
However, To be fair, the greater point is as stated earlier, a defect or issue that effects a small sample of an entire production run can happen or even be expected because of the nature of production knives. Because you have an issue with a few knives doesn't mean you can realistically condemn the entire line. I'd say that about any brand.
I does slightly concern me if the glass breaker will reliably function if needed.
Right, but what I'm saying is, breakage in this manner is especially unacceptable for a black class knife.
