- Sep 19, 2001
well i want to send it back and i called askin bout their warrenty, but northwoods says they dont honor the warranty for bolsterless knives.
As for northwoods, they say that they wont support it because "it is made of stag and everyone knows to not flex a blade with stag scales side to side." their words not mine i promise. but im mean not even the liners were tight. i could move the pivot pin up and down the scales cause it was so long. doesnt that strike you as odd? and a manufaturer defect?
but im very dissapointed with northwoods.
even jsut speaking to the guys at northwoods, it seemed like they didnt really care. i am sure they have alot of great products, but all it takes is one really bad experience with a company
...and as for the blade play, the sclaes, liners, and pin itself move. i get a half inch of movement from side to side. that is alot of movement, even my case/buck/camilus/schrades/saks dont move that much.
from the 2 times i called Northwoods, hoping to get more info, both time it was said that they DO NOT warrant bolsterless knives. nothing was said about quicker repair or replacement through a dealer. i even said "so i basivally have a $150 paper weight?" all the guy who anwsered did was grunt. saying once again that they do not warrant bolsterless knives.
i really like alot of their products but if they dont stand behind them...lets just say that i have alot of companies vying for my buisness...and not jsut mine, but everyones
first off, i never even knew i talked to dave.
second, to my memory, which is pretty good for a 20 year old, he never said anything about shipping it back to the dealer. not a single thing, he jsut said it was not covered by warranty.
now i am in no way an expert on bolsterlee/or bolstered knives for that matter, but i do know this. when i get a band new knife, the first thing i do is check blade play. this had it, except what i considered to be an acceptable amount.
but when i take the edge to my spydeco white rods, LIGHTLY, and then strp on my belt which is kinda slack, and then can stck paper, comp paper, beetween the scales and liners, and the liner and pivot tang then something is wrong. also, my big thing here for me, is that i can, with a covered point, push the pivot pin back and forth. meaning it is not peened correctly. these are all things that i DOUBT i was able to do on my own from 10 passes on the fine rods and 10 more on my belt.
the only thing i told him was that i had a scagel #11 with alot o blade paly and wanted to know if it was covered by warrenty. the straight up said no. this was before they even knew i sharpened it. a straight no is a contradicition to what he told you.
the knife did have play when i got it out of the box. but to me an acceptable amount in a slippy. about as much as my case. but then the scales separated fromt he liner, i can see light on the other side. and i can make the knife have the original amount of blade play by squeezing the two scales together, but then one flex and they are separated again. i dont know if im being to picky about this, but my $20 34OT and $35 Case Trapper have better f&f than this.
Dave is entitled to get the facts. After I read the first post to him over the phone he felt he wasn't given all of them and was led to believe they shipped a dealer a faulty knife and for all we know or he knew they did. Point is he made his decision based on that yet he's damned if he does or damned if he doesn't come up with a reply adequate to please you.! He said, 'in all liklihood his reply would have been different if he'd known about the stropping." We can only speculate as to what that reply may have been. I just relay what he said.
I must admit it does make you wonder. If the knife was faulty new out of the box why go on and sharpen it? If its just a paperweight as he claims then mail the darn thing back as defective to the dealer right there for a replacement which is just what Dave recommened to him. Seems cut and dry to me. If however a guy has a user knife and after its been in the pocket sharpened, used more and then has a problem the reply would be different. Is that so hard to follow? I don't think so.
Bolsterless knives have a warranty like all the others they make by the way. If you experience problems it doesn't mean they won't cover that it means they'll simply attribute it to normal symptoms from operator use instead of them sending out a defective folder. Its not so hard to follow the logic there to me based on the type folder it is and the size pins used and the handle scales used.
What I get is that Dave thought the knife was defective, and based on this, not a belief of operator use/error, he told the customer that there was no warranty. If crbauhs is to be believed, then before any mention of the sharpening was made, he was told quite simply that Northwoods would not be handing out a replacement when Northwoods believed the knife was a factory defect.
There is either a misunderstanding or poor CS.
