It's spring steel but it's not a spring it's a knife. Although it uses spring steel it has a tempering for a cutting instrument. You want edge holding abilities? Well you gotta give up some of the toughness. I think the flat ground blade did very well! If he had tested one of the older grinds the rangers had it would have never broke under those circumstances. But you have to realize that noss is a fairly big guy and that is a lot of stress bouncing on that flat ground blade. Everyone knows that not only the tempering affects the toughness it also loses strength when you use a flat grind. I like the flat ground blades better however since it is far tougher than needed and will cut better.
This is true, but it doesn't relate to the notion that 1095 is better suited to such a knife.
Furthermore, it's still surprising that it broke in the way it did. Even for a full grind blade, it's still quite thick and widely believed to be among the "bulletproof" knives out on the market. If the steel is hardened and tempered to the point that it's so brittle, there's little reason to use 5160, as such treatment negates the main reason to use 5160 in the first place. Which would be toughness.
The bottom line is that it failed in a way that is surprising, and mildly disappointing, considering the construction and reputation the RD series enjoys.
