Everything in SF has to be under 3"s doesn't it?But seriously yeah that sucks.[/QUOTE]
That's the reason for the 3 inch limit in SF![]()
How so? There is no blade length limit in the law in Mass. each city may set its own blade length limit as they see fit.
The 1.5 inch blade limit is for automatics. A normal locking folding knife doesn't have a blade length limit that I could find as long as it doesn't meet the criteria of automatic, gravity, ballistic, butterfly or other description prohibited by MGL. The 2.5 inch limit is within the city limits of Boston.
My father was a police officer for 33 years in a high crime Boston suburb and usually said a folder with a blade of under 4 inches would not be a problem (unless you were a criminal, or it was going to be used as an additional charge during a felony arrest.) He gave me my first spyderco fully serrated endura but mentioned that a police or military was against the law. It will most likely be at the discretion of the officer and if you aren't a criminal chances are you will be fine.
YMMV
Technically there is a state limit regarding what you can carry on any kind of state property, which can include city property depending on circumstance but mostly schools and campuses is where the main concern is.
^^^This might be right (found HERE):
171b. (a) Any person who brings or possesses within any state or
local public building or at any meeting required to be open to the
public pursuant to Chapter 9 (commencing with Section 54950) of Part
1 of Division 2 of Title 5 of, or Article 9 (commencing with Section
11120) of Chapter 1 of Part 1 of Division 3 of Title 2 of, the
Government Code, any of the following is guilty of a public offense
punishable by imprisonment in a county jail for not more than one
year, or in the state prison:
(1) Any firearm.
(2) Any deadly weapon described in Section 17235 or in any
provision listed in Section 16590.
(3) Any knife with a blade length in excess of four inches, the
blade of which is fixed or is capable of being fixed in an unguarded
position by the use of one or two hands.
Though I'm not sure what to make of the part in bold. I'm not sure if it's just referring to fixed blades or if it applies to locking folders.
171c. (a) (1) Any person who brings a loaded firearm into, or
possesses a loaded firearm within, the State Capitol, any legislative
office, any office of the Governor or other constitutional officer,
or any hearing room in which any committee of the Senate or Assembly
is conducting a hearing, or upon the grounds of the State Capitol,
which is bounded by 10th, L, 15th, and N Streets in the City of
Sacramento, shall be punished by imprisonment in a county jail for a
period of not more than one year, a fine of not more than one
thousand dollars ($1,000), or both such imprisonment and fine, or by
imprisonment in the state prison.
(2) Any person who brings or possesses, within the State Capitol,
any legislative office, any hearing room in which any committee of
the Senate or Assembly is conducting a hearing, the Legislative
Office Building at 1020 N Street in the City of Sacramento, or upon
the grounds of the State Capitol, which is bounded by 10th, L, 15th,
and N Streets in the City of Sacramento, any of the following, is
guilty of a misdemeanor punishable by imprisonment in a county jail
for a period not to exceed one year, or by a fine not exceeding one
thousand dollars ($1,000), or by both that fine and imprisonment, if
the area is posted with a statement providing reasonable notice that
prosecution may result from possession of any of these items:
(A) Any firearm.
(B) Any deadly weapon described in Section 653k or 12020.
(C) Any knife with a blade length in excess of four inches, the
171.5. (a) For purposes of this section:
(1) "Airport" means an airport, with a secured area, that
regularly serves an air carrier holding a certificate issued by the
United States Secretary of Transportation.
(2) "Passenger vessel terminal" means only that portion of a
harbor or port facility, as described in Section 105.105(a)(2) of
Title 33 of the Code of Federal Regulations, with a secured area that
regularly serves scheduled commuter or passenger operations.
(3) "Sterile area" means a portion of an airport defined in the
airport security program to which access generally is controlled
through the screening of persons and property, as specified in
Section 1540.5 of Title 49 of the Code of Federal Regulations, or a
portion of any passenger vessel terminal to which, pursuant to the
requirements set forth in Sections 105.255(a)(1), 105.255(c)(1), and
105.260(a) of Title 33 of the Code of Federal Regulations, access is
generally controlled in a manner consistent with the passenger vessel
terminal's security plan and the MARSEC level in effect at the time.
(b) It is unlawful for any person to knowingly possess, within any
sterile area of an airport or a passenger vessel terminal, any of
the items listed in subdivision (c).
(c) The following items are unlawful to possess as provided in
subdivision (b):
(1) Any firearm.
(2) Any knife with a blade length in excess of four inches, the
blade of which is fixed, or is capable of being fixed, in an
unguarded position by the use of one or two hands.
(3) Any box cutter or straight razor.
(4) Any metal military practice hand grenade.
(5) Any metal replica hand grenade.
(6) Any plastic replica hand grenade.
(7) Any imitation firearm as defined in Section 417.4.
(8) Any frame, receiver, barrel, or magazine of a firearm.
(9) Any unauthorized tear gas weapon.
(10) Any taser or stun gun, as defined in Section 244.5.
(11) Any instrument that expels a metallic projectile, such as a
BB or pellet, through the force of air pressure, CO2 pressure, or
spring action, or any spot marker gun or paint gun.
(12) Any ammunition as defined in Section 16150.
(d) Subdivision (b) shall not apply to, or affect, any of the
following:
(1) A duly appointed peace officer, as defined in Chapter 4.5
(commencing with Section 830) of Title 3 of Part 2, a retired peace
officer with authorization to carry concealed weapons as described in
Article 2 (commencing with Section 25450) of Chapter 2 of Division 5
of Title 4 of Part 6, a full-time paid peace officer of another
state or the federal government who is carrying out official duties
while in California, or any person summoned by any of these officers
to assist in making arrests or preserving the peace while he or she
is actually engaged in assisting the officer.
(2) A person who has authorization to possess a weapon specified
in subdivision (c), granted in writing by an airport security
coordinator who is designated as specified in Section 1542.3 of Title
49 of the Code of Federal Regulations, and who is responsible for
the security of the airport.
(3) A person, including an employee of a licensed contract guard
service, who has authorization to possess a weapon specified in
subdivision (c) granted in writing by a person discharging the duties
of Facility Security Officer or Company Security Officer pursuant to
an approved United States Coast Guard facility security plan, and
who is responsible for the security of the passenger vessel terminal.
(e) A violation of this section is punishable by imprisonment in a
county jail for a period not exceeding six months, or by a fine not
exceeding one thousand dollars ($1,000), or by both that fine and
imprisonment.
(f) The provisions of this section are cumulative, and shall not
be construed as restricting the application of any other law.
However, an act or omission that is punishable in different ways by
this and any other provision of law shall not be punished under more
than one provision.
(g) Nothing in this section is intended to affect existing state
or federal law regarding the transportation of firearms on airplanes
in checked luggage, or the possession of the items listed in
subdivision (c) in areas that are not "sterile areas."
I'm sitting here debating on my favorite knives and you know what?
Not being able to carry a folder over 3 inches really really sucks.
There are so many knives I would love to EDC every day, like the Umnumzaan, etc.
Unfortunately, since 3 inches is the limit here, I am reduced to smaller, more petite knives. This really is unfortunate, as I think the sweet spot for awesome folders is around 3.5 inches in blade length.
Anyone else feel similarly?
-Freq
This thread has gone off topic. I am familiar with
my local laws.
My point was to discuss how it sucks that most of the best folders, are over 3 inches in length.
But while we are at it: This whole situation totally sucks. Basically, I have no official source to get a comprehensive law from. Instead, I have to interpret it myself, and rely on forums and shop owners to tell me what is/isn't legal?
Concealed weapons charge ain't no joke, especially if you don't have a sparkling clean record. I find this incredibly frustrating. FYI our gov't sucks ass.
-Freq
Hah, I'm more confused now than I was before...
[...]You're right - as far as I know there isn't anything specifically written in sate law that gives a blade length limit. Even says it here, for what it's worth:
http://www.ninehundred.com/~equalccw/knifelaw.html
"There's no length limit. Seriously."
~Chris
if we are talking laws, I think my feeling is that the law feels too uncertain. Totally lame that there isnt anything definitive about what is legal in my city.
-Freq
Thank you Alabama.
10 bucks for a permit to conceal my pistol, and I've never heard of anyone getting any flack for whatever knife they choose to carry.
You couldn't pay me to live in California!
Last I checked there was no blade length limit anywhere in the Bay Area except Mountain View.
That said, if it bothers you, move. I did, and now I carry whatever I want.
The real shame of it is that the average law abiding citizen even has to consider it.
Most of the laws give folks not involved in any illegal activities an out; but we, and often LEO's, choose to take them at face value rather than considering the, "when used as a weapon", "with the intent to use the same unlawfully against another", type qualifiers. We also read the normal knife into the "switchblade, dirk, ballistic, etc" clauses thinking they apply when they obviously don't. Finally as in California there is often another qualifier for where they can (I should say cannot) be carried. In CA, for example, 4" is commonly thought of as the limit when it is not. 4" is just mentioned in relation to public buildings and meetings.
Local knee jerk statutes passed by people with no real knowledge of knives or guns for that matter are, IMHO, just plainly unconstitutional.
my local laws.
I hear ya. Today at the post office (in a town south of Boston), I pulled out my Fallkniven Tre Kronor (2.7 in blade) as I had to open a box which was also wrapped in shipping paper, and I felt like I was pulling out an AK47. ...
Well, actually, the knife was a violation of federal law. Anything 2.5" or more is illegal in federal facility.
- OS
