- Dec 13, 2010
I just emailed Fallkniven about the uneven lamination and got a very rapid response: Hi,
In general, we accept variations from the all perfect symmetric ground solution as long as the edge still is formed by the powder or VG10 steel. Largely asymmetric ground blades are rejected.
A problem in using laminate blades is that the lamination lines become visible only when the blade get polished which is the final step in the production. Should we reject blades which aren’t 100 % perfect with regards to a symmetric grinding, very few blades would be accepted and the knives left would become so expensive that almost no one would consider to buy them.
We make several blades as laminates and the good reason is that such blades become much stronger and cause less problems for the customer. The negative matter is that the lamination lines seldom are all symmetric but, as a manufacturer we have accepted that as a cosmetic detail with no negative function.
Best regards
Eric Hjortberger
Kinda not that satisfied considering many have said that theirs is perfect, but I still don't see it affecting so the function so I don't care how uneven it is.
Best regards
Eric Hjortberger
