Is that a challenge? I'll take it.
Pick any Fallkniven you like, and I'll build one to eerily similar dimensions with my choice of steel, HT and edge geometry and match the retail price. I'll also put my knife up against Fallkniven's similar model in any cutting test their warrantee will support. The person making the challenge assumes all costs of shipping to a neutral testing party. (put your money where your mouth is). Winner takes all... Fallkniven wins, they get my knife and vice versa.
Disclaimer: I have no beef against Fallkniven. They have great designs and use quality materials.
I am volunteering as the neutral tester. I can't promise I won't keep your sweet knife! But I will promise to be impartial!
Problem is, if I break or damage your knife, you will likely fix it, and make the customer satisfied.
If I break or damage the Falkniven, they will call me names, and assure me that they have tested their knives so any failure is not real, or is the result of gross abuse (even if I have a video of it failing in normal use). They will then tell me to get lost. Their warranty will basically only cover harsh words if it causes the blade to de-laminate from stern glances!
There are much better warranties from production and custom knives for equal money.
This is not to say they are not decent knives. They have above average steel, and do a good job on the grinds. I am a big fan of full height convex grinds. Use it like a knife, and you should have decades of great slicing use. If you happen to have an "oops" moment, though, you will be keeping that knife, and it won't likely be replaced.
Bark River has quite a following. They make some fine knives. If you happen to get one where the heat treat is jacked, or the grind got it way too hot and ruined the heat treat and you get a wavy edge horror, send it back and get a new one. You can get a lemon from most manufacturers. The real issue is how they treat you as a customer. I would tend to stick with forever warranties. 2 year limited warranty, covering only defects in material and manufacturing just is not up to snuff.
