Speedholes,
Beautiful pic of stunning scenery. Where is that?
If you thought that was funny you should have heard the things I was saying when I was building it. "What kind of bird brained frog eating Frenchie would choose a random 23.4mm seat-post inserted into a spacer to fit a 25.2mm seat tube?" Turns out Peugeot would use only French manufacturers for all their parts and the guys making the seat tubes only had one diameter tubing which was of course not a standard size, or so the story goes. Worst deraileurs known to man too, plastic push rod front and stamped paper thin steel with plastic rear. Crankset uses 14 bearings on one side and 12 on the other, just cause they felt like it
Don't forget that they don't use opposite threads for the bottom bracket either, damn non-drive side cup always coming loose! I hated working on french bikes almost as much as I hated working on vintage schwinn bikes. Even the good french bikes would still drive me nuts!
-X
My District was a belt drive. I kept it that way for about 1 month, and had it warrantied twice for skipping issues before I switched it to a chain.
They claim the belt is more "efficient", but fail to consider how tight the belt needs to be to prevent skipping. I had to run mine so tight that it actually tensioned the bearings in the rear hub and put a ton of drag on the drivetrain. $50 for a rear sprocket (with spacers), front chainring, an 8-speed chain. Now it's smooth, quiet, and completely worry-free.
