O.K. Boys. . . I need help with the folder. Thumb Stud? or Blade Hole?r
Low Profile Thumb Stud or Blade Hole?
  • Thumb Stud
    Votes: 0 0.0%
  • Blade Hole
    Votes: 0 0.0%
  • Total voters
    0
Originally posted by Normark
Hey Guys..
I'm Really happy you guys like my idea soooooo much...
Don't everyone rush to say "Good Idea Eric":)
LOL
"Good Idea Eric"...Isaacson. LCC style.
Jerry, Go with a beefy dual thumbstud like only you can do...
Sorry Eric Normark
"Go Heavy or Go Home"
If you use a thumb hole, you'll have to pay Mike Turber royalties for using his design...
Mel
A hole by its nature is weak. I have never bought a Spyderco because the hole weakens the blade.
I want to be confident that my knife can stand lateral forces to pry doors open and handle whatever emergency situation I find myself in.
I want my knife stronger than me.
Don't blades usually break near the tip? And don't you need to drill a hole in the blade for a thumbstud, anyway?:confused:
How many Spydercos break at the hole? If you want your knife to be stronger than you, are you really in the market for a folder?
Thumbstud all the way ,maybe even a 1/2inch bolt for a stud .
Holes :barf: might work well on smaller and thinner blades, and men with lady fingers...... but not on a busse blade .
I also keep hearing that it will cost less with a hole design ,but if the knife has a well designed thumbstud I wouldnt care about the cost !
Good Evening All-
....to be confident that my knife can stand lateral forces to pry doors open and handle whatever emergency situation I find myself in....
Not a flame, but how many knives have you broken during use? If this is a genuine concern, a thumb-stud or opening hole isn't going to "make or break the deal" for a user like you....especially for a folder.
My suggestion would be to get the best folder you can for typical use, but have a Steel Heart or Battle Mistress in the trunk for that "1%-level" of need when you truly need a stout fixed blade.
BTW, Jerry, how are things coming along for this project?
~ Blue Jays ~
For a user like you -----------:rolleyes:--------------------------------
A drilled out thumbstud ,is alot smaller then an open thumb hole ! :footinmou
When im buying a folder ,the whole point is trying to find one as strong as it can be .
Originally posted by SPARK
The actual physical date of the move will be from Apr 11 until Apri 14, so hopefully we'll just be down for a *long* weekend.
Taken from:
http://www.bladeforums.com/forums/announcement.php?s=&forumid=713
It's gonna get interesting now ain't it...:p
Oh, and put me down for a hole, but not some freakish overgrown eyesocket like those @#%$# spydies....NO, make it rectangular - or even better, use the outline of a combat blade as the shape - that would be neat. :eek:
But it's still a hole.
Again, don't blades typically break/fail at the tip, along the cutting edge, or at the pivot or lock of a folder?
Are Spyderco or Strider folders known for breaking at the hole?
I'm really asking this question (again), I'm not claiming to be a knife guru.
Edit: Here's a series of good posts on this topic (especially the thread linked at the end):
http://www.bladeforums.com/forums/showthread.php?s=&threadid=250831
It would appear that a small drilled hole has at least the potential to be a bigger stress riser, due to its sharper transition, than a large radiused thumbhole.
It would also appear that proper design & execution will probably trump any concerns about either choice. So perhaps the choice ought to be made on functionality rather than blade strength.
I don't think Jerry would have offered the choice if he thought one was inherently weak.
Seeing the recent banter about holes and blade strength, I gotta speak up again - - why not use a toggle style thumb-stud (below)? This puts the stud behind the stress line between pivot bolt and working part of the blade. Effectively, this removes the hole-issue. (Ha!)
TT2Toes
attachment.php
