OKay, getting back to the TTT diagram, let's see real quick if I have the gist of it. Those notes you guys sent are going to take a while, assuming I can stay awake through it! Anyway, if I read right, when talking about the curve on the left of the diagram, the top of the curve is basically the temperature we want to take the knife to, the so called critical temp, yes? As the curve comes down and around (the nose of the curve), the time that matches the tip of the nose is the amount of time you have, more or less, to bring the steel from the critical temp to cooled to transform the austenite into martensite (the hard stuff), right? So, for O1, in other words, that means if it cools within about ten seconds in the quench, it will harden, which is how that 10 second numebr got thrown into the discussion.
That also explains why I'm not finding a temper line of any type on my O1 knives, because I am quenching them the same way I quench 1084 and 1095, which is clay coat, dunk the whole thing in ATF/Oil. I would guess this is what is meant by a "shallow" hardening steel. The nose of the diagram must be further to the left, giving you less time to make this crucial transformation, correct? So, I am likely getting a decent hardening of the steel to take place, actually I know I am, and tempering correctly for the RC I want, but the temper line is not there because the portion of the steel under the clay still cooled enough in the ten second period that it hardened all the way, which is what we established already.
So, to get a temper line, (and I'm talking temper line, not hamon) if I want one, on O1 I'll have to change my quench tank setup and make sure the soft area stays out of the oil altogether or it'll harden to some degree. Whew, got it. Now, unfortunately, this business about soak times, carbides, etc is not information that can be gleaned from the TTT diagram, correct?
