now, matching up the guard with the handle material to have a nice, uninterrupted flow;
still plenty of material to remove, but it looks like things are coming together;
Happily, I have found that there are no gaps between the guard, spacers and handle!
Before I glued the handle on, I only pushed the tang pin far enough into the tang to find out whether it lined up closely enough or not. The hole in the tang was a little off- it was off shy of 1mm toward the front of the handle. Once I filled the handle with glue, I hammered the pin all the way through, and I guess what happened was it pulled the knife into the handle somewhat. The reason I know this, is that there WAS a gap between the guard and handle before assembly, and now it's gone.
If I had driven the pin all the way through just to test my fit, I was worried I'd ovalize the hole or cause some other kind of damage. But, the pin fits tight, there are no gaps at all around it, and the guard fits tight and true.
I think I was really lucky this time.
Anyway, I think I'm done with this for today. It's just about there, but it is probably a good idea to finish the handle up with some fresh eyes and once I get to handle the knife a bit as is;
