Cvrobinson
Going to hell, Iβll be back, anyone need anything
- Dec 19, 2017
Wordle 578 4/6
Wordle 578 4/6
Wordle 578 4/6*
Wordle 578 4/6*
whoever said the third times a charmWordle 578 4/6
Yeah, I've scored lower the two previous days because I went with the "more obscure" word, and then today I chose the "less obscure" word and had the same thing happen. My intuition is broken.whoever said the third times a charm![]()
It's hard because 'obscure' can mean a couple of different things when you're picking. In one way, I don't think this word is obscure at all, just uncommon, if that makes sense. Example: GELID would be an obscure word because it basically just means COLD, and it would be obscure and mostly pointless to use GELID instead. So it's obscure in the sense that it is almost never seen in normal writing or speech because there are other, much more common, words, that mean the same thing.Yeah, I've scored lower the two previous days because I went with the "more obscure" word, and then today I chose the "less obscure" word and had the same thing happen. My intuition is broken.
This is true wordle nerdle material right here. I love it.It's hard because 'obscure' can mean a couple of different things when you're picking. In one way, I don't think this word is obscure at all, just uncommon, if that makes sense. Example: GELID would be an obscure word because it basically just means COLD, and it would be obscure and mostly pointless to use GELID instead. So it's obscure in the sense that it is almost never seen in normal writing or speech because there are other, much more common, words, that mean the same thing.
AORTA was an uncommon word in terms of 'how frequently does one use this word in normal, nontechnical conversation' (OK, not as uncommon as today's word, but the principle...), but it's literally the only word that means what it means, so in a sense it's not obscure, just that in normal writing or speech you rarely have the occasion to use it.
free accountAm I the only one that just googles "wordle" each day and does it that way? No account, and my stats randomly reset here and there, but that's fine with me.
hard mode, I play hard mode without the setting, every guess made could be the answerAlso, anyone know why some of the results have an asterisk...X/6*?
Sorry, the X was meant as a variable...number from 1-6. The asterisk was the question, which @Cvrobinson answered as indicating hard mode.I have it bookmarked and play it each day w/o an account and save all of my results to a spreadsheet.
I've got a free library account to the NYT which allows me access to WordleBot which I have to log onto each day after I play the game to report the results for the current and prior day's games.
X/6* is the designation used when you fail and take more than 6 tries to solve the word.
I used to think @r8shell was crazy when she said it was easier on hard mode. Then I thought Iβd give it a try and Iβm hooked. Canβt go back nowSorry, the X was meant as a variable...number from 1-6. The asterisk was the question, which @Cvrobinson answered as indicating hard mode.
Used to?I used to think @r8shell was crazy when she said it was easier on hard mode. Then I thought Iβd give it a try and Iβm hooked. Canβt go back now![]()
Have now accepted it as factUsed to?
