Cougar Allen
Buccaneer (ret.)
- Oct 9, 1998
Aha! Posts crossed, but now I see Geothorn is not the only one affected after all. Back to the drawing board....
Que Geothorn/Slingblade voice:Ren the devils trailboss said:Could it be that....
I'm sorry if my posting about Rat Finkenstein's signature freezing my browser has raised a ruckus with Rat Finkenstein and everyone else looking to pick a fight, but, if there are others having the same difficulty as me, then maybe a chain of coicidences could be added-up to discover the problem. I'm open to there being a difficulty at my end, upon my computer, but, until Rat Finkenstein started using the dated "chicletsforme.jpg" signature, I hadn't had any IE6 freezing unless it was caused by "iexplore.exe" 'Not responding.' I haven't had any "iexplore.exe" freezes for awhile now, when I've given the 'three finger salute,' and it was only any thread with a Rat Finkenstein post that caused IE6 to freeze.Cougar Allen said:Aha! Posts crossed, but now I see Geothorn is not the only one affected after all. Back to the drawing board....
geothorn said:If averageguy is also experiencing IE6 freezing up on threads containing Rat Finkenstein posts, as well as me, then our computers have something in-common...beyond Rat Finkenstein's signature freezing both of our browser's. The "obvious" cure would be to politely ask Rat Finkenstein to change his signature, but he would probably raise a stink to the U.S. Supreme Court about someone messing with his right to Free Speech.
I'm glad that you, for one, were understanding what I was getting at, rather than Rat Finkenstein thinking that I was targeting him for signature potshots.Ryan8 said:This is pretty much what I knew you were getting at.
The issue could well be between my ISP and the image host. However, if, out of all of the surfing that I do, all of the images and advertisements that I download, Rat Finkenstein's signature sometimes loading, sometimes not, and ONLY Rat Finkenstein's "chicletsforme.jpg" is freezing my IE6, well, that would narrow everything down. Rat Finkenstein changing his signature would help, but, judging from his reactions, I somehow doubt that he would humor me, thusly.Ryan8 said:What if the issue is actually between your ISP and the image host? Changing the image won't help.
No, obviously not. However (again), why is the same alleged spyware on my computer only freezing IE6 when I've loaded up a BladeForums' thread containing Rat Finkenstein's signature? That cannot be explained away by spyware.Ryan8 said:Should he have to change his signature if it is spyware (or another issue) on your machine that's causing this?
You're assuming that the problem is on my end.Ryan8 said:The problem is on your end. You can filter it easily enough yet you ignored my suggestion.
I appreciate your trying to help, Ryan8, I really do. However, I think that excluding a file and image host merely so that Rat Finkenstein's unnecessary and worthless signature image doesn't crash my browser is way too extreme.Ryan8 said:Ok, I have an even easier solution. I'm assuming you're using Windows.
geothorn said:I appreciate your trying to help, Ryan8, I really do. However, I think that excluding a file and image host merely so that Rat Finkenstein's unnecessary and worthless signature image doesn't crash my browser is way too extreme.
I'm certain that others use the same host, that have more worthwhile things to use that host for than for crashing browsers. I don't want to exclude everything from that host because something originating there may be worth seeing/reading.
Yes, thanks, I've disabled signatures in my User CP section. Yes, it has gotten rid of signatures, and, therefore, the image causing my browser to freeze.CODE 3 said:GeoThorn;
Go to your user CP, and disable signatures.
After you have done this, let us know if you still have problems.
You and Averageguy are the only people reporting this problem so far.
Thank you.
geothorn said:Now everyone's signature is missing all because one signature froze my browser. Hopefully no one else will be required to shut off their viewing of all signatures at BladeForums because of this single individual's troublesome image.
JFC already........SHUT UP!! No one is removing their sig because only you and your buddy are having problems with it. Now your life is even emptier and more meaningless because you can't read everyones sig. Get over it.geothorn said:Now everyone's signature is missing all because one signature froze my browser. Hopefully no one else will be required to shut off their viewing of all signatures at BladeForums because of this single individual's troublesome image.
GeoThorn
I've not been "whining," chiclet whore. What's a "chiclet whore," one might ask? A chiclet whore is someone that posts at BladeForums with chiclets in their posts. They are people that don't realize that the Reputation Point system no longer exists, but they're holding onto their chiclets, for some reason. That would fall into the category of beating a dead horse.Ryan8 said:No, they'll have the common sense to filter it or use a different browser instead of whining about it. I offered you simple solutions, you chose to be unrelenting.
I apologize for not taking your advice, but, like other of your brethren, The Order of Chiclet Whores, I wouldn't take any advice that you'd give me. Ignoring Rat is the best, least extreme method to use...and, it wasn't one of your "helpful" suggestions. My signatures are again enabled, so, don't worry about the extreme choices I make, ok?Ryan8 said:My solutions have less impact than disabling signatures, and there are other very, very significant benefits to using Privoxy. You in fact chose the most extreme route and continued to whine about it.
No thanks, chiclet whore. I don't listen to whatever you say, and, if anything, I'll keep writing, more and more, because you've told me to shut up. I think that doing exactly the opposite of what you tell me is the best thing to do.m1marty said:JFC already........SHUT UP!! No one is removing their sig because only you and your buddy are having problems with it. Now your life is even emptier and more meaningless because you can't read everyones sig. Get over it.
BTW---These folks are looking for you.....
