I just went back to try again and noticed that there is a lot of wax on my wheel. I'm going to try and remove some. I would still like to hear your answer.
You should be able to work up a burr on the grit wheel. If you a re-profiling or starting a new edge you may want to use a fine grit grinding wheel first, but be careful. The grit wheel I used was quick at moving metal too - so much so that the paper wheel/rouge was all that was needed.
Be very careful. It's easy to overheat the edge with any grinding wheel. A belt sander is much easier to use without generating excess heat.
And just how is it easier to use a belt sander without generating excess heat? Most belt sanders I have seen and used will remove metal much faster (which means more heat) than my paper wheels with the proper amount of wax on it. Of course if you really bear down on the blade (which of course is UN-neccessary) you can burn up any blade on any type of sharpener. Moderation in all things is a good thing.![]()
a buddy of mine has a high def vid camera and i might get him to help me make some new vids. there is not much to mounting the wheels on the motor, just dont torque them down too tight. since i only use 1 wheel at a time, i have to switch wheels and i just get the nut finger tight. when i turn the motor on it tightens the nut up to the point where i have to use pliers to loosen it up.
i do have a few short vids out showing how i work up a burr. since it only takes a short time to work up a burr the vids are not very long. the vids i made buffing the burr off are longer.
