I can tighten my para 2 all the way down, and it still has 0 friction and 0 blade play. Correct me if i am wrong, but spyderco's bushing does the same thing as CRK, but is a cheaper version and might not last as long with wear.
I didn't say they were designed the same, actually I know they aren't. More specifically my question is this, Do the titanium handles tighten down on the bushing and not the tang or what?Actually, you are wrong. It is designed differently, works differently, and is made to different tolerances.![]()
I am asking because I do not own a sebenza.![]()
Blue Locktite is good stuff but the Teflon tape is really difficult to use in that application. It is designed to prevent leaks in pipe threads and is quite slick. If you try using it on large standard threads it doesn't hold and often you'll end up over torquing due to the lubed threads. If you use it in very small applications like this it seems I, at least, end up with a pile of it above the female threads and none in the threads and no locking.If any of the screws become loose after adjustment, one can just use some Blue Loctite or some Teflon tape to keep the screws set just where you want them.
Can't quite picture the friction point on some if overtightened. Do the scales go out of parallel causing the bushing to bind? Did you modify the Mannix bushings by using shorter ones and allowing the washers to ride between scale and tang?
Give me a para 2 without the bushing pivot, and it gets closer to perfection then imo. ...
The "bushing" on a Sebenza rides on a separate pivot pin and the blade rotates around the bushing. So there are 2 contact points between the pin and the blade. The photos on the CRK site has a good photo of exactly how it works.
http://www.chrisreeve.com/sebenzaclean.htm
The bushing and pivot pin are one single piece on the Spydies. It's directly screwed against the liners while the blade rotates around it. So there is 1 contact point between the "bushing" and the blade. And the shoulder on the pivot pin prevents the liners/scales from being too tight.
The difference is tolerances is apparent where almost every Sebenza is buttery smooth with practically no side play regardless of how tight the pivot pin is. The looser (relatively) tolerances on the Spydies can result in a bit of side play while others are smooth and tight. I have yet to find an unmodified Manix 2 that will stiffen up by over-tightening the pivot screws. But a few Para 2s appears to over-tighten if the stop pin screws are tightened as well. I think messing with both these screws can create an angled low spot that can put sideways pressure on the blade tang.
I have my Para 2s adjusted to my satisfaction and my "user" Manix 2s have modified pivot bushings to allow for tighter adjustment. It does defeat the "fool proofing" built into the design and nullifies the warranty on these 2 knives but I can't stand side play. Loctite prevents things from going out of adjustment.
I got two para 2 -one black handle /regular blade and one digicam /black blade and both have very little side to side play .I was very dissapointed to find that and I'm thinking of ways to eliminate that blade play .One thing I might do is sand just a little the bushing so that the washers on both sides can touch both the blade tang and the liners . Does anybody think this would help eliminate blade play .It will be great if somebody who has dissasembled they para 2 could post pis of the bushing and the washers .
Yeah, I came home and tried that. I'm eating my words.One consolation is that my re-adjusted S90v Para 2 is just as good. Side by side, it's as wiggle free side to side as the small Sebbie and just as smooth. Both blades fall with gravity alone. :thumbup:
Try tightening the stop pin screws.
Lenny
I have a Para2 on the way, but I've had my eye on the CRK Seb. The big difference is the price with the Seb costing nearly 3x the price. Does anyone own both and do they still prefer to carry the Seb or Para 2.
How can this be of any help -there is no up and down play .Could you explain ?
