- Aug 6, 2020
The blades were dipped in hot white vinegar for a few minutes. This turns the blades black with patina. I then rinse off the blades with water and let the blades air dry. Next I rub the blades lightly with very fine steel wool. Then I use the knife so the patina isn’t too even. That’s all. If it does not look right I repeat the process. This process works best for the Tidioute knives with the satin finished blades. With the Northfield polished blades the patina does not want to take as easily.How did you acquire such an even patina? That looks fantastic!
What steel wool would you recommend? I’ve used 0000 and it doesn’t seem to do anything at all.The blades were dipped in hot white vinegar for a few minutes. This turns the blades black with patina. I then rinse off the blades with water and let the blades air dry. Next I rub the blades lightly with very fine steel wool. Then I use the knife so the patina isn’t too even. That’s all. If it does not look right I repeat the process. This process works best for the Tidioute knives with the satin finished blades. With the Northfield polished blades the patina does not want to take as easily.
Keep rubbing. #0000 Fine steel wool is what I use. I will also sometimes use an 8000 3M pad.What steel wool would you recommend? I’ve used 0000 and it doesn’t seem to do anything at all.
What number pattern is this? This knife looks great. I’d love to try and find one.
That one is a 2015 #15 with a sheepfoot main blade and cap lifter secondary. It was a SFO for Gun Stock Jacks. Basically, it is a Beer Scout with Bloodwood handles and a banner shield.What number pattern is this? This knife looks great. I’d love to try and find one.
