I hope you did not answer Matushka Rossiya's call to armsI too live in a similar climate (i'm not hiding from anyone so here: 64.73715° N, -156.93066° E).
There's plenty of broken Eswings around (i likes the remnants,make for some nice bottom-tooling at the forge),but not from the cold*.
As 42 says it's largely a hypothetical problem as the tool warms up rapidly from use. We had this discussion before,more than once,and the consensus was that given a modicum of care the issue is avoided easier by just paying attention to what you're doing vs seeking some Unobtainium as head material.
There's more danger the further South you go as the species get harder,and Square_peg had always wisely warned about them Doug fir knots on a cold morning...
But South or North it'd be an accident that would likely chip your axe,like here in a desperate situation if you whack the edge into that sno-go ski carbide ,why you're likely to bugger up that blade no matter what the T outside!
So if you just use your head and take care with where and what and how you aim that axe it'd probably work better than the fanciest of alloys.
* i'm sure that if you Wanted to you can slam an Estwing flat enough on a cold-enough day to fracture it,however all breaks i've ever seen were from the vapor trapped and corroding the thin metal of the handle at juncture with shank.
Pi$$ poor design,that,with all the force concentrating there as well,but the worst about them things is how hard the handle rubber gets in the cold. Lethal-slick in certain mitten/glove palm material...
I hope you did not answer Matushka Rossiya's call to armsand meant to type 64.73715° N, -156.93066° W, instead of 64.73715° N, -156.93066° E
I've been paid with great satisfaction, instruction and a very fine axe.I have been paid professionally for axe design work
Truly the greatest reward of design, though. What you learn in the process and being able to bring an idea to reality.I've been paid with great satisfaction, instruction and a very fine axe.
(Call it banter, call it palaver, a bit never did do harm.)
For me it was all the friends I made along the way.Truly the greatest reward of design, though. What you learn in the process and being able to bring an idea to reality.
Both. The degree to which steel is rendered brittle depends on the ductile-to-brittle transition temperature of the particular steel/its inherent toughness and the method/circumstances of use. The range at which this usually occurs is normally only in extreme cold, however.Honest question: Do the colder temperatures actually matter and make the steel more noticeably brittle, or is it more a matter of the wood being chopped more solidly frozen? Or both?
Actually it's Western Hemlock you have to watch out for. The knots can be glass hard. They're a danger even in warm weather but especially so in cold weather. Western Red Cedar knots can also be hard enough to chip an axe though it's knot as common as with hemlock.There's more danger the further South you go as the species get harder,and Square_peg had always wisely warned about them Doug fir knots on a cold morning...
And a Big Ti Knife as well.Titanium axe head.
