- Sep 9, 2003
On the chart above you will see the curve for soft steel yields at a very low level of force, this is because it is “ductile” (easily deformed) that is after all the meaning of soft. While the fully hardened steel requires the most force to deform because it is “strong”, able to resist deformation. Fully hardened steel resists deformation to the point that the only way for it to give when its limits are reached is to come apart. This is the ultimate strength, in fact that is what it is referred to on the chart when a steel has yielded and just can’t take any more. Many graphs will show the ultimate strength as a point beyond the peak in ductile strength but will recognize that in reality ultimate strength is the point of total failure where the steel will just come apart.
Measuring the force required to flex a piece of steel while in the proportional range is a waste of time! Any sharp engineer could crunch some numbers and give you the actual force without ever holding the blade as long as he had the dimensional cross section measurements. Which brings up the point that if one wants to change the amount of force to flex , we have established that they can forget about the heat treatment, but they can simply change the thickness versus length and get instant results. It takes little force to take a fillet knife to 90 degrees, and it may even avoid taking a permanent bend. On the other hand a blade that is over ¼ “ thick will require a cheater bar and will be more prone a permanent set because of it. If you want a decided advantage in the bend test without even knowing how to heat treat, make a blade that is wide and thin.
This is why when person tells me they made a blade that “flexed” to a certain degree and returned to true, and then insist on feeding me a line about their heat treating- I don’t care! It isn’t relevant, and the only thing they have given me information on is how they grind their blades.
Under the accurate definition of “strength”, soft spines do not make stronger knives, they make them weaker (a better term would be ductile or tough). And this takes us to the next issue- the huge confusion over tensile ductility and impact toughness…
