- Apr 20, 2013
OK, more pitchers fur yah. Went back and sanded with some grits in between 800 & 1500 looking to see if I could get it a little *more* polished. Came out about the same.....still OK with it. Also got the coating off the rest of the tang and polished up the "tactical" end.....
Haven't really worked on the edge, but as of now it will just POWER through cardboard. Immediately had to clean it off, tho. In case it's not apparent to anyone what's under all the cosmetic surgery:
If you need to scare your children on Halloween, I'm available....no costume required....
Last night finally got the scales and handle prepped; used a little cutoff to make some "lands" for the handle cutout. Fitted and scuffed up everything.
Stainless pins are a LOT harder than the brass ones I've used...chucked 'em into the drill and used 80 grit and a triangular file to give them some grip.
Then some last fitting before mixing the epoxy.
Ready for glue:
I ask you, what work can take place without some lubricant? In the foreground is my birudashi purchased from daizee at the Gathering a couple of weeks ago. I love that thing already. Slips into my pocket and disappears until I need it.
Ready for glue:
