Greetings,
I need help with a tapered tang. The knife is 4mm thick and a full tang construction. I wanted to try a tapered tang and I don't know how to proceed from here.
The scales go to where the brown tape starts and I really, really don't want to grind or sand past this point, because the rest of the knife is finished....
My problem is that I cannot get the tang flat. I started on the grinder and then sanded it with sandpaper glued to a granite surface. Everything I try seems to just make it worse.
When grinding on the belt grinder I held the tang perpendicular to the running belt and not horizontally because the wheel of my flat platen probably would have messed up my ricasso area.....
Also how do I make the taper stop exactly at the point where the scales end, especially when the scales are rounded?
I really need some advice here because right now I'm lost.
Best regards
Best regards
