- Feb 25, 2011
I am getting better at detecting a burr/wire edge, but now I think I am having trouble at removing it.
I chased a burr back and forth on a knife I sharpened to 1000 grit on the Edge Pro. It's a 154 CM blade sharpened to 30-deg inclusive. I tried removal in cork - no luck. Then I steepened the sharpening angle to 20-deg (from 15-deg) and used a couple very light edge-trailing strokes (stropping motion) with the 1000 grit stone. I am not sure I can still feel the burr. I may have scrubbed it off, but the blade doesn't seem to cut *quite* as well as before I steepened the angle. Also, I can no longer detect the burr under 60x magnification, but in fact, BOTH sides of the bevel seem to have that shiny burr-edge - probably I am looking at a tiny micro-bevel added by steepening the stone angle, but I can't tell if either side has a burr/wire edge anymore due to the micro-bevel (if that's what it is).
How do you recommend I proceed? How do you remove a burr/wire edge without steepening the angle of the bevel too much?
Thanks - your help is greatly appreciated!
