- Feb 25, 2011
Thanks, David. You 'da man!
IDK about this for burr removal. I can't believe that cotton (denim) actually REMOVES a burr - more likely just straightens it out. I do like a similar method for detecting a burr, though, as cotton fuzz will cling to the burr when lightly stropped against the thigh.
And I agree, it is a good way to detect if burrs are there. I think I actually see more value in that, on denim, than in actually being able to remove them with it.
Wait, I'll bet Bill's jeans are loaded with diamond dust - that's why the method works so well for him.
Sometimes I think that may be why it works for me as well. I developed a habit of quickly wiping the blade on my jeans after stropping on compounds. Any compound in a wax or oil binder will cling to the blade somewhat, and so some of that I'm sure has been wiped onto the thighs of my jeans. Diamond, silicon carbide, aluminum oxide, chromium oxide have all been deposited on my jeans, and I'd bet laundering doesn't clean all of it away. Probably got a nice 'witches brew' of abrasive built-in on my pants' legs now.
David
I've been playing around lately with using a couple different compounds on thin cardboard, over glass, for stropping my edges. The compounds I've been using the most are some 3-5µ 'white' Ryobi compound I picked up at HD, and also some Simichrome polishing paste (~ 9µ, per the mfr.). The cardboard I use is the simplest and most easily available, just some kleenex/crackerbox-type stuff, using the inside (unfinished) face. I used a little spray adhesive to lightly tack the cardboard to the glass. The adhesive is a type that allows temporary bonding; spray the cardboard and wait a few minutes for it to become tacky; then just press it to the glass. It can easily be removed & replaced when it gets worn out or too dirty...
David
From my test above. It started out quite sticky/grabby on a fresh coat of white compound, then turn toward slick proportionally to the level of blackeness. This blacken-packed thin cardboard strop is slicker than a leather strop with similar level of built up. And stopped working altogether. After that, I also tried (again) on balsa. Balsa behaved almost like leather but resulted with burr and added more than 5*/perside convexity to the edge.OwE and bluntcut, how was the feedback though on the cardboard? I can imagine that the surface is very thin and slick?
I bought a complete paperwheel kit from grizzbear sometime back. It works so so + impractical to use indoor (mostly at my desk). The RES white-compound is ~ 20% better than the bulk white-compound but costs over 10x.You guys realize that what you are describing is exactly what happens when using the slotted wheel on the paper wheel system. Using the white compound, which quickly turns black, but stropping the knife none the less. I have used the slotted wheel to buff a new Opinel without touching the gritted grinding wheel, and wound up with a razor edge. Then when the knife got dull, ran it again only on the slotted wheel and again razor sharp. No outside additional stropping needed. You can buy just the slotted wheel alone, and not buy the whole system. (About $30) I was using a leather strop after the slotted wheel, and my edges were degrading. Now I only use the slotted wheel for stropping and can re-sharpen a lot of knives without re-grinding, so no loss of metal. (Ok, a minute amount) Try it, you might like it.
Blessings,
Omar
I'm going to have to trade knives around with all of you some time. I have completely different experiences and methods for burr removal than 99% of people who talk about it.
The only stropping that removes a burr for me is power stropping on my belt sander with Sears white compound. Drawing through a board doesnt remove them. Only increasing the angle fairly dramatically (60-80 degrees inclusive) reliably removes a burr on all the steels I deal with. Some dont need that big an angle jump, but it works on them all, so I use it for consistency. I use my Sharpmaker for finishing usually, and deburr then give 10 or so more passes per side. Some steels will whittle head hair after just the medium flats.
Hey bluntcut, I'm still looking over what you've posted here and 'digesting' your feedback.I've gotten quite a lot of inspiration in reading what you've posted, and your 'balanced strop' post from a short while back is what motivated me to try the 'white' compound in a similar technique as demonstrated in your video there. The faster-paced stropping demo'd in your technique has made a difference, which 'looks' less controlled, but really seems to work for me. There's something valuable in that, for sure.
I'm absolutely convinced, after hangin' around here for a few years and reading about how everybody gets a knife 'sharp', there are at least a million or so variables in determining how a particular method works (for some) and doesn't seem to work as well when attempted in another's hands. Different strengths (literally) in one user's hands, as compared to somebody else, will influence how aggressively a given method/tool/compound seems to work. And then there's speed of stroke, length of stroke, angle of approach, and the 'feel' for the feedback as well, and then how one individual interprets and responds to that feedback.
I'm still trying to figure out how/why the method I posted seems to work so well for me. I tried the same thing (thin cardboard over glass) with some green stick compound on a Schrade 1095 blade yesterday (which is about the sharpest edge I have), and didn't like the results at all. It seemed to round/blunt/over-polish the edge, and the 'bite' quickly left it. Oddly enough, when I use the same exact compound on the 'nap' side of my leather belt (free-hanging), it works great on that same blade. I quickly restored the bite in the edge by going back to the white Ryobi compound on the cardboard/glass; seemed almost automatic in how quickly it worked.
David
