Pocket Carry--Front or Back?
Curious...
How do you carry your EDC knife (folder)?
Front pocket or back pocket and why?
RF normally unless I feel like carrying two blades, than one in each.
how does back pocket carry work? it seems like that'd be very uncomfortable. I always do inner-waistband carry
I carry tip-down folders right back pocket: Military or Chinook. No problem.
I have tucked fixed blade sheaths into that pocket, which is not real comfortable sitting down.
Neither...side pocket of carpenter jeans because it doesn't seem to interfere with movement.
Back pocket for clipped folders. I wedge it into the outside seam. I keep my SAK in a front pocket.
I keep the folder in the back because I have so much other stuff in my pockets already. This keeps pretty accessible without getting in the way of digging out keys and such. So far I have not had any problems sitting. Then again I don't yet own any wide folders so my method of carry could change in the future.
Front pocket. I don't carry clipped so back pocket is generally not an option for me, the knife tends to fall down and lay horizontally. If I carry back pocket I end up having to slide it up all the time. Looks like I'm scratching my butt. :cool:
I carry my in my right front pocket. Why? Because that is what works for me.
I'm a lefty that carries in my right pocket ! :D
Usually a large folder like my OD-1 , Groove , S-2 etc and then a small Slipjoint in the watch pocket.
Tostig
Large Sebenza clipped inside right front pocket.........No reason why really, I am right handed and its just easier access for me.
Most of the time a large pe clipped in rt. front pocket and i always have a
se dragonfly loose in my left rear pocket.
I carry only waved knives, Emersons or stuff I waved. I'll keep a framelock CQC7 with a normal right handed clip in my left rear pocket. It will draw forward into an icepick grip, edge out. In my right pocket I like to have a Super CQC7 framelock with the clip mounted for a lefty, so I can draw in the same forward wave icepick grip.
Left pocket knife:
Right pocket knife (primary):
Right front pocket waved tenacious, comes out super quick! its there cause its always needed. i also keep my 110 on my belt if i really need to, otherwise its in my backpack. there's also a lock-back razor blade in my left front pocket for boxes.
