...How about a serrated Endura, oreven Tenacious? I own both of thiose, and they tear up cardboard boxes real good.
I can't speak for XHP, and to be honest I haven't really used S30V all that much either. Nothing against the steel really, it just happens that I've never really used an S30V knife for any extended amount of time. Not that I can recall, anyway. I will say though that I like M390 and CTS-204P much better; or at least that I like the knives I have in that steel (a Kershaw Bareknuckle and Spyderco Delica, respectively). It holds an edge very well and is easy for me to sharpen with the tools and skills I possess. I find it easier for me to maintain a sharp edge with those steels than I ever did with S30V. Actually, I can get a sharper edge, but that maybe could be attributed to improvements in skill and not just the steel (probably both).
Extreme edge holding is useless if you can't maintain it, whether by lack of equipment, skills, or both. Maxamet or S110V might take a hell of a long time to dull, but it eventually will and if you can't resharpen it, it'll be an expensive, useless knife shaped object rather than a knife. Of course, on the opposite end of the spectrum you have knives that are easy to sharpen but don't hold an edge worth a shit.
What you need to find is what works best for you. For example, I've been a big fan of VG-10 for a long time. Once upon a time it was a higher-end steel, a bit below 154CM/ATS-34, but is generally considered a a not-quite-low-end steel these days; it ain't great, but it's much better than 8Cr13MoVWtFBBQ and the like. But for my purposes, it has served fantastically. It holds an edge for as long as I usually need it to, and with my skills and equipment I can easily touch it up. Plus there's just something about VG-10 combined with my tools and skills that I can get it sharper than just about anything else I've used, with only a few very new exceptions (the aforementioned M390/204P and K390). I know my limitations and needs, and S110V or Maxamet would be a bad choice for me.
Welcome! I think for your uses both steels will work quite well. I would go with what ever one you like the looks of better.Having owned both kershaw and spyderco though, I would say spydercos quality is better than kershaws. But Kershaw does have a really good warranty service if you should need it.
I think your choices are solid, I think cold steel has decent options in your price range as well. I still prefer spyderco just because they are USA made. I would pick that option out of those 5 listed. Good luck!
Ok, maybe I should have provided more details so users here didn't think I'm getting a knife just to be cutting up cardboard boxes all day. My use is specifically for occasionally cutting up cardboard to burn in a fireplace. This might happen couple times a week or not at all in a given week. It's based on if I received any packages that week. I can understand the box cutter recommendation if I was cutting a lot of boxes and frequently.
I just want an all around knife that won't dull easily, including if I need to use it to trim a stick I might find outside for fetching with my dog. For automotive purposes, it's more for cutting off things if the need arises. I once had a piece of bumper detach and rub on my front wheel. I had to pull over on the freeway and was stuck because I couldn't cut off the offending piece and yet didn't want to have the car towed just for that reason (and no one to call to bring me a knife at that time). Embarrassingly, I had to borrow a knife from the police who had stopped to see what's up to cut off the damn thing.
If I really go down to it, I guess my concern is related to the apparent edge retention differences between the XHP and M390 steels. But I don't really see any sort of strong consensus in the replies here that one is better than the other. So maybe I'll just wait for few days to see if Kershaw M390 comes in stock and if not, I'll go with the Spyderco XHP steel. I guess the XHP is also nice in terms of being easier for a novice to sharpen.
A box cutter or utility knife is best for sure. My personal favorite is the good old Stanley non retractable one. But it requires a sheath.
Next best cardboard knife is a Dexter Russel net knife. The thin serated blade will cut miles of cardboard before it needs to be sharpened. Then it just needs to have the back rubbed flat on a stone.
Smatchet.
The point regarding the difficulty of sharpening makes sense. The XHP is not supposed to be any more difficult to sharpen than the S30V. Now regarding M390, I have seen users mention both that it is not hard to sharpen and a few saying that it is. It's also good to know that Maxamet is also tough to sharpen. Since you sharpen M390s, I was wondering what are you using to sharpen. I recently bought the Sharpmaker with the default rods. Do you think it would be necessary to get the diamond rods if I do get the M390? I read that the diamond rods don't last long, so some people get a regular diamond sharpener and then overlay it on one of the medium rods to get the correct angle.
If I were to go with the regular steel knives, I would probably get the Ontario Rat II in D2 steel, since it looks great to boot. The edge retention rankings go only so far though. Both M390 and XHP are ranked as 9/10 in edge retention, but I've seen tests that show the M390 edge lasts much longer than XHP despite the same rank. Now the D2 is ranked as 7/10 and VG-10 as 5/10, so presumably the edge would last for a much shorter period. In real world, I wonder how much of a difference this translates to and how noticeable it is. Maybe users who regularly utilize both a super steel and a "regular" steel can shed some light on this aspect.
The Spyderco Chapparal is made in Taiwan...
It's generally recommended not to burn cardboard in a fireplace or indoor stove because it contains toxic chemicals (including the ink used to print on cardboard).
Well, now you have me looking up burning cardboard in a fireplace. I usually burn a few to start a wood fire, but I guess this is something I'll have to look into more now. I even see articles about the negative effects of burning wood in a fireplace. Funny things you learn online - I asked about a knife to cut up cardboard for burning, and I'm learning that maybe shouldn't use a knife to cut up cardboard or cut up cardboard to make a fire in the first place or use the fireplace. Hahaha.
By the way, I didn't know that they make boxcutters where it's so easy to replace the blade. Mine is a 10 year old craftsman boxcutter where you have to unscrew the damn thing to replace the blade, so most of the time I don't care to go through that trouble. Now the nice boxcutters that have been posted here can cost as much as a decent knife (some cost as much as M390 steel knife). So I don't know if I'm being cheap by thinking that I'm better off investing in a decent knife instead that has many more uses than a box cutter. Plus it seems like I might stop cutting up cardboard soon thanks to Orange here...
